rpm counter
ALIJAMSHED131
rpm counter
PostPosted: Fri Nov 22, 2013 10:23 am     Reply with quote
#include <16F877.h>
#include <ce_lcd.c>
unsigned long int a=0,b=0,d=0;
#int_ext           //////////////////error is here in this function
void ir (void)  {
b++;
output_toggle(pin_d0);
}                 ///////////////////////////error ends here
#int_timer0
void rpm (void)   {
a++;
set_timer0(5);
void main (void)
enable_interrupts (global | int_timer0 | int_ext);
ext_int_edge (l_to_h);
setup_timer_0 (RTCC_DIV_256);
set_timer0 (5);
lcd_init ();
   while(true) {
          if (a == 78)  {
          d=(b*60);
          a=0;
          b=0;
   printf (lcd_putc,"\fRPM = %ld", d);
In this code the INT of pic 16f877 is being used to detect rising edge. But the problem is that after detecting first rising edge, the INT pin remains high. I think that interrupt flag needs to be cleared, but in C language how could this be done ?
PostPosted: Fri Nov 22, 2013 12:28 pm     Reply with quote
First this line. See the manual.
