how to get display LCD module DEM 16215 to work?
artohautala
PostPosted: Tue Nov 19, 2013 1:04 pm     Reply with quote
I'm trying to get DEM 16215 2x16 display to work ...
I followed this document to initialize it:
http://www.display-elektronik.de/DEM16215SYH-LY.PDF
but no success...
does anybody know to make things going ?
brgds
arto
PostPosted: Tue Nov 19, 2013 3:15 pm     Reply with quote
Try the Flex driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
The data sheet for that LCD says it requires at least a 40 ms delay after
power-up before you can write to it. The flex driver has a 15ms delay
because that's what is normally required for HD44780 compatible LCDs.
I suggest to just add an additional delay before calling the flex driver init
function:
delay_ms(40); // Do this delay before calling lcd_init
See if that works. Of course, you have to setup your pin definition
statements at the beginning of the Flex driver, so they match your
hardware connections between the LCD and the PIC.
artohautala
PostPosted: Sun Nov 24, 2013 10:55 am     Reply with quote
function:
ok,
It was not so simple but very much thanks for your answer ..
If someone is using that display here is way to things going ...
to get it initialzed ...
all the best
-arto-
void lcd_init(void)
      /*INIT FOR 4 BIT INTERFACE
      LCD:n ohjaussignaalit:
      (PIN_D1) = lcd_reg  = RS   //LCD:N reg select, 0 = käsky, 1 = data
      (PIN_D0) = lcd_en      //LCD:n enable
      LCD : n dataportti on D4...D7, 4 bittiä, D2 JA D3 ei käytössä, ne on nyt inputteja
      PIN C0 on LCD write / read, 1 = read 0 = write */
      delay_ms(60);           //min. wait time after powerup 40ms
      //reset LCD display:
      output_high(RW_LCD);      //read LCD
      enable_lcd();
      output_low(RW_LCD);      //write LCD
      enable_lcd();
      //lohko 1-3,function set
      PORTD = 0B00110000;
      enable_lcd();
      PORTD = 0B00110000;
      enable_lcd();
      PORTD = 0B00110000;
      enable_lcd();
      //lohko 4,function set DL = BIT D4 = "0"
      PORTD = 0B00100000;
      enable_lcd();
      //lohko 5,function set DL = BIT D4 = "0"
      PORTD = 0B00100000;
      enable_lcd();
      PORTD = 0B10000000;      //D7 = "1" on 2 riviä, D6 = font, muut X
      enable_lcd();
      //lohko 6, display OFF
      PORTD = 0B00000000;
      enable_lcd();
      PORTD = 0B10000000;
      enable_lcd();
      //lohko 7, display ON
      PORTD = 0B00000000;
      enable_lcd();
      PORTD = 0B00010000;
      enable_lcd();
      //lohko 8, entry mode set:
      PORTD = 0B00000000;
      enable_lcd();
      PORTD = 0B01100000;           //D5 on I/D, D4 = shift , normaalisti "0"
      enable_lcd();
      //noi on oltava
      PORTD = 0B00100000;
      enable_lcd();
      PORTD = 0B10000000;
      enable_lcd();
      PORTD = 0B00000000;
      enable_lcd();
      PORTD = 0B11000000;      //bit D5 cursor on/off
      enable_lcd();
      PORTD = 0B00000000;
      enable_lcd();
      PORTD = 0B01100000;
      enable_lcd();
