Using a simple CAN BUS protocol example.
sonyoungdong
PostPosted: Fri Nov 15, 2013 6:28 am     Reply with quote
Hi, I'm making a simple example code based on the example file of CCS, "EX_CAN.c". I am using PICF4580. My code is as below.
#include "set4580.h"
#include "can-18F4580.h"
#byte p_d = 0xf83
#byte PIR1 = 0xf9e
int8 count;
#int_timer2
void isr_timer2(void) {
bit_clear(PIR1,1);
   count++; //keep a running timer that increments every milli-second
   struct rx_stat rxstat; //구조체 정의는 어디서?
   int32 rx_id;
   int in_data[8];
   int rx_len;
//send a request (tx_rtr=1) for 8 bytes of data (tx_len=8) from id 24 (tx_id=24)
   int out_data[8];
   int32 tx_id=24;
   int1 tx_rtr=1;
   int1 tx_ext=0;
   int tx_len=8;
   int tx_pri=3;
   int i;
   for (i=0;i<8;i++) {
      out_data[i]=0;
      in_data[i]=0;
   printf("\r\n\r\nCCS CAN EXAMPLE\r\n");
   setup_timer_2(T2_DIV_BY_16,255,16);   //1초마다 발생.
   can_init();//Initializes PIC18xxx8 CAN peripheral.
   enable_interrupts(INT_TIMER2);   //enable timer2 interrupt
   enable_interrupts(GLOBAL);       //enable all interrupts (else timer2 wont happen)
   printf("\r\nRunning...");
//Data receive
      if ( can_kbhit() )   //if data is waiting in buffer...
         if(can_getd(rx_id, &in_data[0], rx_len, rxstat)) { //...then get data from buffer
            printf("\r\nGOT: BUFF=%U ID=%LU LEN=%U OVF=%U ", rxstat.buffer, rx_id, rx_len, rxstat.err_ovfl);
            printf("FILT=%U RTR=%U EXT=%U INV=%U", rxstat.filthit, rxstat.rtr, rxstat.ext, rxstat.inv);
            printf("\r\n    DATA = ");
            for (i=0;i<rx_len;i++) {
               printf("%X ",in_data[i]);
            printf("\r\n");
         else {
            printf("\r\nFAIL on GETD\r\n");
      //every two seconds, send new data if transmit buffer is empty
      if ( can_tbe() && (count > 153))
         count=0;
         i=can_putd(tx_id, out_data, tx_len,tx_pri,tx_ext,tx_rtr); //put data on transmit buffer
         if (i != 0xFF) { //success, a transmit buffer was open
            printf("\r\nPUT %U: ID=%LU LEN=%U ", i, tx_id, tx_len);
            printf("PRI=%U EXT=%U RTR=%U\r\n   DATA = ", tx_pri, tx_ext, tx_rtr);
            for (i=0;i<tx_len;i++) {
               printf("%X ",out_data[i]);
            printf("\r\n");
         else { //fail, no transmit buffer was open
            printf("\r\nFAIL on PUTD\r\n");
Ignore some Korean comments Very Happy
EX_CAN.C file is a source file and this includes head files can-18F4580.h, set4580.h(Default setting file for rom writing). And can-18F4580.h includes can-18F4580.c.
I am writing this list because I am not sure whether this header files are right or not.
Anyway, when I tried to test this CODE using USB-to-CAN with Minimon program, no data is received and transmitted....
I don't know what problem exists in my code.
PostPosted: Fri Nov 15, 2013 11:52 pm     Reply with quote
Post the contents of this file:
Post a link to the schematic of your PIC board. Post your compiler version.
sonyoungdong
About set4580
PostPosted: Tue Nov 19, 2013 5:54 am     Reply with quote
set4580.h
#include <18F4580.h>
#device adc=8
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES BBSIZ2K //2K words Boot Block size
#use delay(clock=40000000)
18F4580.h
//////// Standard Header file for the PIC18F4580 device ////////////////
#device PIC18F4580
[header file deleted]
Version is 4.068
thank you for your interest
Do not post header files. Read CCS Forum Policy and Guidelines.
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
-Forum Moderator
PostPosted: Tue Nov 19, 2013 12:13 pm     Reply with quote
Ex_Can.c is written to work with the CCS CAN Bus Development kit:
http://www.ccsinfo.com/product_info.php?products_id=CANbuskit
The program is designed to work with the MCP25050 CAN Bus i/o
expander chips:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010402
You are not using an MCP25050, so I think you need to make the
changes listed below:
Comment out the two lines shown below, and substitute the new
initialization lines shown after them:
//   int1 tx_rtr=1;
//   int1 tx_ext=0;
int1 tx_rtr=0;  // *** Changed to 0
int1 tx_ext=1;  // *** Changed to 1
Also there are some problems with your #fuses:
Change the first one in bold to NOLVP. I doubt that you are using a Low
voltage programmer. Those programmers are hand-built from
instructions on hobbyist websites. Almost everyone uses a normal
programmer, which should use NOLVP.
Also, I don't see that you are using PortB as analog inputs, so it's best
to keep PortB as digital i/o. Change the next fuse in bold to NOPBADEN.
Also, ideally the #use rs232() line should always have the ERRORS
parameter as shown below:
The compiler defaults to 8 bits and No parity. You don't need to specify it.
