DHT22 - PIC 24FJ64GA002
asiklariskostas
PostPosted: Mon Nov 11, 2013 9:21 am     Reply with quote
Hello everyone. I need your help with DHT22 sensor and PIC24FJ64GA002. According to a previous topic, i tried to compile your code to my project, but my hyperterminal is blank - i don't receive any messages. Can anyone help me??? Thanks anyway!!!
I use PCWHD Compiler (version 5.008).
Here is the program that i've made:
#include <24fj64ga002.h>
#include <stdio.h>
#FUSES NOJTAG                   //JTAG disabled
//#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PR                       //Primary Oscillator
#FUSES NOCKSFSM
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES HS                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD                    //Internal External Switch Over mode disabled
#FUSES WUT_DEFAULT
#FUSES WPOSTS1                  //Watch Dog Timer PostScalar 1:1
#use delay(xtal=16000000)
#use rs232(baud=9600, xmit=PIN_A0, rcv=PIN_A1,bits=8)
int bExit;
int DHT_Data;
int iByteIndex;
int CRC;
void DHT_Start(void)
   // Here we send the 'start' sequence to the DHT sensor! We pull the DHT_IO pin low for 25mS, and
   // then high for 30mS. The DHT sensor then responds by pulling the DHT_IO pin low, and then pulling it
   // back high.
   Output_low(PIN_B3);
   delay_ms(25);
   Output_high(PIN_B3);
   delay_us(30);
   // Here we wait while the DHT_IO pin remains low.....
   bExit = False;
   set_timer2(255);
   while (!input(PIN_B3) && !bExit);
   // Here we wait while the DHT_IO pin remains high.....
   bExit = False;
   set_timer2(255);
   while (input(PIN_B3) && !bExit);
int8 DHT_ReadData(void)
   // This subroutine reads a byte of data (8 bits) from the DHT sensor...
   int8 iIndex;
   int8 iValue = 0;
   for(iIndex = 0; iIndex < 8 ; iIndex++)
      bExit = False;
      set_timer2(255);
      delay_us(30);
      if (input(PIN_B3))
         iValue = iValue |(1<<(7 - iIndex));
         bExit = False;
         set_timer2(255);
   return iValue;
 // Here we send the initialization sequence to "wake up" the DHT sensor, and put it into
      // data transmission mode.
      DHT_Start();
int i;
      // Here we read a total of 5 bytes of data (40 bits) from the DHT sensor. For the DHT-11 sensor,
      // the integer data is contained in the 1st (Humidity), and 3rd (Temperature) bytes transmitted,
      // and the 2nd and 4th decimal bytes are always zero (0). For the DHT-22 sensor, the integer data is
      // is contained in the 1st (Humidity), and 3rd (Temperature) bytes transmitted, and the decimal
      // data is contained in the 2nd (Humidity), and 4th (Temperature) bytes transmitted. The 5th byte
      // contains the CRC byte for both sensor types.
      for (i = 0; i < 5 ; i++)
         DHT_Data(i) = DHT_ReadData();
      // Here we calculate the CRC by adding the 1st four bytes, and looking at only the lower 8 bits.
      // This value should match the 5th byte sent by the sensor which is the CRC byte!
      CRC = DHT_Data[0] + DHT_Data[1] + DHT_Data[2] + DHT_Data[3];
      CRC = CRC & 0xFF;
      if (CRC != DHT_Data[4] && !bExit)
         fprintf(PC, "CRC Error, expected: %Lu, and received: %u\n\r", CRC, DHT_Data[4]);
      if (bSensorType == DHT11)
         Humidity = DHT_Data[0];
            Temperature = DHT_Data[2];
         //fprintf(PC, "Humidity: %ld%%\n\r", Humidity);
         //fprintf(PC, "Temperature: %ldC\n\r", Temperature);
            Humidity = Make16(DHT_Data[0], DHT_Data[1]);
         Temperature = Make16(DHT_Data[2] & 0x7F, DHT_Data[3]);   //Strip off the sign bit first!
            //Temperature /= 10;
            if (DHT_Data[2] & 0x80)
            Temperature *= -1;
         //fprintf(PC, "Humidity: %3.1w%%\n\r", Humidity);
         //fprintf(PC, "Temperature: %3.1wC\n\r", Temperature);
PostPosted: Mon Nov 11, 2013 10:42 am     Reply with quote
Since you're not receiving any messages, it sounds like a communications problem.
Start with a simple 'hello world' program to get the serial stuff right.
Simple things like...
1) proper RS232 xcvr( like MAX232) connected right ?
2) proper connections to PC(pin 2 is rcv, 5 is ground if DE9 connector)
3) PIC running at correct speed? The 1Hz flashing LED program will confirm this...
4) disable any and all peripherals that may be connected to the I/O pins you're using.ADC,PWM,etc...must be turned off.
5) confirm that Hyprerterminal is running. simple wire from pin 3 to pin 2 creates a 'loopback.press a key it MUST be displayed on screen,if not,well there's a huge problem that must be solved.
You have to program in 'steps'.Confirm the simple things work BEFORE you cut your main code.
hth
jay
