memcpy want to copy some value
bauche
PostPosted: Tue Nov 05, 2013 5:22 am     Reply with quote
Hi i try to figure how to send only some data from reveived string...not succesfull...want to extract like: D8 FE 52 F7 in the string...
(data in received buffer :FF FF FF FF FF 06 80 00 0E 00 D8 FE 52 F7 05 05 03 1D 18 00 00 06 28 23 00)
 char* Received;
 char new[26];
 Received=fgetc(COM1);
 fprintf(COM2,"%c",Received); // working see all value
 memcpy(new,&Received[10],1);
 new[10] = 0;
 fprintf(COM2,"%c",new); // not working
can somebody show me how to do it???
Thanks...
oxo
PostPosted: Tue Nov 05, 2013 5:38 am     Reply with quote
For the example data, show us what you expect to see as the output.
bauche
PostPosted: Tue Nov 05, 2013 5:41 am     Reply with quote
Hi ....send the result value in hex by com2
Regards
PostPosted: Tue Nov 05, 2013 5:57 am     Reply with quote
total confusion!
- fgetc() result is char not pointer type
- Received[10] is neither in declared variable space nor loaded with a value
- fprintf(COM2,"%c",new); is not printing new[10] or new[0]
Suggestion: Learn quite a bit about C data types, characters, strings, pointers and string functions
bauche
PostPosted: Tue Nov 05, 2013 6:02 am     Reply with quote
i know it's no good ...it's not working Smile
and how i can extract some value for my received buffer and send it on com2???
use substring?? memcpy??
regards...
PostPosted: Tue Nov 05, 2013 8:41 am     Reply with quote
Fvm has pointed out some of the problems. It is just not correct C. Comments inline:
 char* Received;
//received is now a _pointer_ to a char, but as yet points nowhere.
//No memory saved for it to point to, and the initial value is
//indeterminate...
 char new[26];
//new is now a pointer to a 26 character memory area.
//You now write a single received byte into the _pointer_. Garbage.
//_Single byte_.
//Here the incorrectly stored pointer, will be automatically cast 'back'
//to a character. It'll sort of work, but it is wrong in multiple ways.
//'Received[10], will be 10 greater than the value received. Could be
//pointing anywhere in memory. You could retrieve anything.
 new[10] = 0;
//fprintf, expects to receive a character. You are giving it the address
//of the first byte of 'new'. Of course it won't work.
You need to get a C primer, and read the section on pointers and arrays, then try some simple exercises on a PC C. Because of the error trapping on this, you will get errors when you try to talk to memory areas you shouldn't which may help you to understand just how wrong everything is.
There is only about one line of the code that is not a glaring error...
