Access violation error on compile
nazoa
PostPosted: Mon Nov 04, 2013 6:42 am     Reply with quote
Hello
I am seeing (erratically) the following error:
--- Info 300 "main.c" Line 888(0,1): More info: * Access violation at address 024F340E in module 'PCD.dll'. Read of address 7F84A690
*** Error 44 "main.c" Line 888(0,1): Internal Error - Contact CCS OUTPUT FILE O
When it happens, it always happens when the compiler is attempting to write the COF file. I am using PCWHD V4.128 on an Win XP machine. Strangely, occasionally I can fix it by adding blank lines at the end of the main.c file.
Any suggestions?
dyeatman
PostPosted: Mon Nov 04, 2013 9:52 am     Reply with quote
I would suggest you need to report this to CCS.
support@ccsinfo.com
Google and Forum Search are some of your best tools!!!!
