yusef
spi pic24hj23gp202 |
Posted: Sat Nov 02, 2013 11:37 am |
hi
i want contact two pic24hj32gp202 with spi but does not work Please help me :
master :
#include <24hj32gp202.h>
#fuses hs
#use delay (clock=20m)
#PIN_SELECT SDI1=PIN_B5
#PIN_SELECT SDO1=PIN_B6
#PIN_SELECT SCK1OUT=PIN_B8
#PIN_SELECT SS1OUT=PIN_B9
int16 i ;
main(){
setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_16|SPI_MODE_8B|SPI_SS_DISABLED);
while (1){
for(i=0;i<100; i++){
spi_write(i);
slave :
#fuses hs
#define LCD_ENABLE_PIN PIN_B13
#define LCD_RS_PIN PIN_B15
#define LCD_RW_PIN PIN_B14
#define LCD_DATA4 PIN_B0
#define LCD_DATA5 PIN_B1
#define LCD_DATA6 PIN_B2
#define LCD_DATA7 PIN_B3
#define LCD_TYPE 2
#include <lcd.c>
#include <stdlib.h>
void lcd_clear () {
lcd_send_byte(0,0x01);
lcd_send_byte(0,0x02);
char str[16];
int16 i ;
main(){
lcd_init ();
setup_spi(SPI_SLAVE|SPI_SS_DISABLED|SPI_MODE_8B);
while (1){
lcd_clear();
i=spi_read();
lcd_gotoxy(1,1);
itoa (i,10,str);
printf(lcd_putc, "i=%s"str);
delay_ms(400);
Posted: Sat Nov 02, 2013 12:06 pm |
A couple of comments without looking too far:
SPI_SS_DISABLED, should normally _only_ ever be used on a slave....
Get rid of the delay in the slave. It will wait for the data to arrive, and this should be what synchronises the loop. Clear the lcd after the byte arrives, then you have the whole wait time to see it (see below).
You may be falling out of sync, since clearing an LCD, takes a long time.
Add a delay before starting in the master. Unless you are very lucky, and the slave starts first, the link will never synchronise.
Generally, SPI is _much_ better used with slave select. Without this, you have to do something to ensure the connection starts synchronised....
why fiddle around with itoa. Printf, can format the data for you:
printf(lcd_putc,"\fi=%ld",i);
This will also clear the LCD for you....
Then, depending on your compiler version, you may need to set the TRIS on the pins for the SPI. CCS does this automatically for 'fixed' peripheral pins, but most versions do not do this when the pin is relocatable.
