Kalman filter
tomik-po11
Kalman filter
PostPosted: Fri Nov 01, 2013 7:26 am     Reply with quote
I'm doing as a school project a quadcopter, and we're having trouble while filtering the entrance of the 10dof module. Is there any working library of kalman filter?
Also, we're going to use PID, so we'll be needing the library of that also, if there's any.
Thanks!
ezflyr
PostPosted: Fri Nov 01, 2013 7:38 am     Reply with quote
Which PIC processor are you using, and what is your compiler version?
John
PostPosted: Fri Nov 01, 2013 8:00 am     Reply with quote
As far as the PID library..PID is kinda 'specific' to the 'plant' that it's controlling as well as the 'feedback' that is used.
It's all in the details.Type of motors used, speed controllers, feedback.I use encoders 95% of the time as they're far more accurate,fast and stable. Some use PWM for the motor drive,though good old LM12CLKs work real good.Fun when you reverse thrust the blades!
Have you 'googled' your project? There are 1,000s of hits about quadcopters,PICs and code.
Most everyone here will help out in debugging your code but won't give you 'up and running' code.
hth
jay
tomik-po11
PostPosted: Fri Nov 01, 2013 8:08 am     Reply with quote
I'm using an 18f46k80 microcontroller and my ccs version is 5.008.
Yeah, I know there're many projects on the web, but it's been quite difficult for me to find something easy to understand and that's running well.
ezflyr
PostPosted: Fri Nov 01, 2013 8:43 am     Reply with quote
I've been part of a hobbyist group working on autonomous fixed wing model aircraft for the past few years. We currently have a Sig Kadet flying
pre-programmed 'task's' using GPS-derived waypoints. This project has been a lot of fun!
A couple of really good places to get information are:
http://autopilot.sourceforge.net/
http://DIYDrones.com
John
