or at least a simple ccs code to config the mrf49x chip correctly and transmit/receive a string.
thanks.
asmboy
Posted: Mon Oct 28, 2013 8:12 am
this is not a trivial part to program for , or to design into a product.
serious RF knowledge is required
and very good data programming skills are needed too.
Accurate device ID and
the sync data value checking routines alone will be quite challenging.
it is a very serious project and
it will NOT be a simple driver to write, let alone TEST.
best of luck
