help with 16x2 lcd
nerdnicky
help with 16x2 lcd
PostPosted: Mon Oct 21, 2013 9:45 am     Reply with quote
Guys i need to run a 16x2 lcd with pic 16f684. I am not aware of how to wire it using 8 bit interface. I just want to print the characters using the commands from uc. I don't want to use the lcd drivers so that i could understand the hardware. Please help me.
gpsmikey
PostPosted: Mon Oct 21, 2013 9:58 am     Reply with quote
If you want to learn to "understand the hardware", then you are going to need to spend the time to look at the data sheet for the LCD (or the controller chip on it), study the timing and then figure out how to achieve that timing with the processor of your choice. Be sure to observe the reset timing - most of those LCD chips take a bit of time to "wake up" and many people overlook that when they try talking to it. The data sheets for the chips specify the configuration for both the 4 bit (nibble) mode as well as the 8 bit modes. Talking to the LCD controller is not that complicated, but you need to spend the time to study the data sheet and understand what the timing requirement is.
mikey
mikey
PostPosted: Mon Oct 21, 2013 1:59 pm     Reply with quote
LCD tutorials:
http://www.geocities.com/dinceraydin/lcd/
https://coefs.uncc.edu/sjkuyath/files/2012/04/LCD__Interfacing_with_Microcontrollers_tutorial1.pdf
http://www.studentcompanion.co.za/Courses/Programming/PIC/LCD.aspx
Find more with Google.
