Pointer to array of chars
zzeroo
PostPosted: Fri Oct 18, 2013 9:01 am     Reply with quote
Hi, I do not found a CCS valid solution for this problem. The following code are from a arduino library that I try to port for my PIC18.
I've a array of chars like this one
const unsigned char Tahoma10[] ={
    // Font Header
    0x01, // 0x00: Monospace, 0x01: Proportional
    0x02, // 0x00: horizontalLeft,  0x01: horizontalRight
    // 0x02: verticalCeiling, 0x03: verticalBottom
    0x20, // Start character
    0x5F
Where bounding_box_t is a stuct, but that's not the point.
typedef struct {
   char x1;
   char y1;
   char x2;
   char y2;
} bounding_box_t;
The arduino library works with functions like this one (just the prototype for simplicity).
bounding_box_t draw_text(char string, long x, long y, char font, char spacing);
If I call these I've got a compiler "Error#165 No overload function matches". I think this happens because the pointer that way.
draw_text("Z", 10, 10, Tahoma10, 1);
PostPosted: Fri Oct 18, 2013 11:14 am     Reply with quote
Post a small compilable test program that shows the error, and
post your compiler version. I should be able to copy and paste the
program into MPLAB, without any editing, and compile it and see the
error message.
