Accessing only 1 byte of a SRF
alan
PostPosted: Fri Oct 11, 2013 12:02 am     Reply with quote
Hi All.
How do I access only one byte of a SFR in a 16 bit PIC?
#word __P1DTCON1 = getenv("SFR:P1DTCON1") //PWM1 Dead time register1
For example I want to update only the high byte of P1DTCON1.
For normal RAM I just use a struct and union.
Regards
PostPosted: Fri Oct 11, 2013 12:57 am     Reply with quote
Look at #BIT and #BYTE
You can just use the struct and union though. If you 'pre-declare' a variable, then #byte can be used to locate _that variable_ at a location.
The variable can be a structure, just as easily as any other variable type.
So declare the structure and union as you would for RAM, then use:
#byte variable_name = getenv("SFR:P1DTCON1") //PWM1 Dead time register1
Which will then locate the variable called 'variable_name' at the specified location.
alan
PostPosted: Fri Oct 11, 2013 1:47 am     Reply with quote
Thanks Ttelmah,
Didn't know you could do it that way.
I started doing it as you suggested and the code are now shorter, however I still seem to misunderstand something as shown in the following code.
.................... typedef union {
....................  uint16_t WRD;
....................  struct {
....................    uint8_t High;
....................    uint8_t Low;
....................  }BTY;
.................... } __DEADTIME;
.................... __DEADTIME __DeadTimeREG;
.................... void SetDeadTimeRegA(DutyCycle) { \
....................   __DeadTimeREG.BTY.Low &= (uint8_t)(0xC0);  /*Clr values*/ \
09B2:  MOV     81A,W4
09B4:  LSR     W4,#8,W4
09B6:  AND.B   #C0,W4L
09B8:  MOV.B   W4L,W0L
09BA:  MOV.B   W0L,81B
Why does the compiler do a LSR and then do the AND in W4 move it W0 and then back to the byte?
I don't think you would need more than this.
  #asm MOV.B     __DeadTimeREG.BTY.Low,W0
       AND.B   0xC0,W0
       MOV.B   W0,__DeadTimeREG.BTY.Low
  #endasm
Doesn't compile Embarassed but hopefully you get the drift.
Probably doesn't make much difference the 2 extra instructions as it is a dsPIC33EP64FJ12MC202, but I like to understand for when I am in a jam regarding speed.
Regards
FvM
PostPosted: Fri Oct 11, 2013 6:18 am     Reply with quote
To avoid any overhead, define #BYTE registers
#byte __P1DTCON1L = getenv("SFR:P1DTCON1")
#byte __P1DTCON1H = getenv("SFR:P1DTCON1")+1
PostPosted: Fri Oct 11, 2013 6:34 am     Reply with quote
Second guessing why the assembler does things is often quite 'fun'....
As an experiment, I tried changing the union to use a two char array, instead of the separate high/low defines.
Code changes to:
union splitter {
  unsigned int16 word;
  char bytes[2];
union splitter __using_array;
#byte __using_array = getenv("SFR:PMDOUT2") //PWM1 Dead time register1
....................    __using_array.bytes[1] &= (0xC0);
0254:  MOV.B   PMDOUT2.7,W0L
0256:  SE      W0,W0
0258:  AND     #C0,W0
025A:  MOV.B   W0L,PMDOUT2.7H
If however the char is changed to 'unsigned', then using this or direct #byte defines, or the named array, then it always performs the 16bit access.
It looks as if this is it's default way of accessing a 'byte' to give an empty top byte in the case of unsigned types....
PostPosted: Fri Oct 11, 2013 12:39 pm     Reply with quote
Actually this does the same.....
It appears it is CCS's default way of accessing a 'byte', if it is unsigned. It uses the rotation to clear the top byte, even if the result only uses the low byte. If signed, it uses SE instead.
