18F26K80 CAN bit rates 250 and 500
oxo
PostPosted: Mon Oct 07, 2013 3:01 am     Reply with quote
Hi all,
I have this chip working at 125kbit/s, but no matter what I try, I can't get it to work at 250 or 500 kbit/s.
I have a 16 MHz xtal, ad 4x pll, so clock is 64 MHz.
Settings for 125 kbit:
CAN_BRG_PRESCALAR 15
CAN_BRG_PROPAGATION_TIME 2
CAN_BRG_PHASE_SEGMENT_1 7
CAN_BRG_PHASE_SEGMENT_2 3
Can anyone share their working settings for 250 and 500 please?
oxo
PostPosted: Mon Oct 07, 2013 3:22 am     Reply with quote
OK, so now i have settings for 250kbit, #
I dropped the pll, so clock is now 16 MHz.
These work for 250.
#define CAN_BRG_PRESCALAR           1
#define CAN_BRG_PROPAGATION_TIME    4
#define CAN_BRG_PHASE_SEGMENT_1     7
#define CAN_BRG_PHASE_SEGMENT_2     1
and in theory, these should work for 500, but they don't
#define CAN_BRG_PRESCALAR           0
PostPosted: Mon Oct 07, 2013 5:28 am     Reply with quote
I don't have that PIC but general comments...
It could be a 'bug' in your compiler version, that's why it's important to tell us what you're running.
Also, dump out the listing and confirm the correct register is being set/cleared according to the PICs datasheet.
Since you're only changing...#define CAN_BRG_PRESCALAR 1 ...
it should be easy to find and see what's happening.
It might be that ' CAN_BRG_PRESCALAR ' is being changed twice unknown to you, from 'extra' code that shouldn't be there....
hth
jay
oxo
PostPosted: Mon Oct 07, 2013 5:36 am     Reply with quote
Compiler 5.012
And all the code is from the j1939 example of ccs
PostPosted: Mon Oct 07, 2013 11:20 am     Reply with quote
Download and install the MBtime can bus baud rate calculator:
http://www.intrepidcs.com/support/mbtime.htm
Detailed instructions on how to use it with CCS:
http://www.ccsinfo.com/forum/viewtopic.php?t=22138&start=8
newguy
PostPosted: Mon Oct 07, 2013 11:28 am     Reply with quote
Further to what PCM has posted, I had a lot of trouble with the CCS CAN functions with later version 4 compilers (4.100+) and dsPICs. I ended up having to completely set up the CAN registers myself. I have no experience with the version 5 compiler yet.
oxo
PostPosted: Mon Oct 07, 2013 12:51 pm     Reply with quote
Thanks mate. I already tried It. Still the 500k doesn't work.
PostPosted: Mon Oct 07, 2013 1:32 pm     Reply with quote
Other thing to remember is that as frequencies get higher, so do the requirements to keep bus capacitance's low, terminate properly, etc. etc..
