I have a problem to generate a PWM-signal...
I want that a LED is dimmed by a PWM-signal. I know that there are simpler methods but I will learn how I can use a PWM.
I use the dsPIC33FJ256MC710A, the PCD compiler from CCS and the dsPICDEM MCLV development board.
Posted: Sun Oct 06, 2013 3:30 pm
I don't have the PCD compiler but since no one else is answering, I'll try
to help you.
Look in the PCD compiler manual to find a commonly used PWM function
for a dsPIC33 with Motor Control PWM, such as set_motor_pwm_duty().
Then do a forum search for that, and all Motor Control dsPIC33's:
