Is this kind of I2C connection possible? [Solved]
arunb
PostPosted: Mon Sep 30, 2013 1:39 pm     Reply with quote
I am trying to use a 18F2620 for i2c connection, I intend to run the 18F2620 on 5 VDC but the i2c pins would be pulled up to 3.3V.
My question is will the 18F2620 drive the SCL and SDA pins to 5 VDC ?? or will the voltage level remain at 3.3V ??
thanks
a
PostPosted: Mon Sep 30, 2013 1:49 pm     Reply with quote
That PIC has the SMBus option for the hardware i2c pins. Enable it.
Add SMBUS to the #use i2c() statement. Then it will work with 3.3v pull-ups.
I2c doesn't drive high levels. That's what the pull-ups are for.
It only pulls down (drives low).
arunb
re
PostPosted: Tue Oct 01, 2013 1:00 pm     Reply with quote
thanks for the help, its working now
thanks
a
