RX interrupt of PIC18F46k22 is not working.
hwryu
PostPosted: Wed Sep 25, 2013 5:41 pm     Reply with quote
I took 4 days to fix the problem of PIC UART. I am using PIC18f46k22.
when sending character to PC via TX , PC received character well.
But when sending character to PIC via TX, RX interrupt is not working.
I used rx interrupt with PIC16f877 before. Is different how to use rx interrupt in both of these PICs.
Help me . I am tired.
#include <18F46K22.h>
#device *=16 adc=10
#device ICD=TRUE
//#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES BORV42 //Brownout reset at 4.2V
#FUSES PUT //Power Up Timer
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOHFOFST //High Frequency INTRC waits until stable before clocking CPU
#use delay(internal=16Mhz,clock=64Mhz,RESTART_WDT,clock_out)
#use rs232(UART1,baud=19200,stop=1,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,restart_WDT,errors,stream=SER1)
#ZERO_RAM
#include <stdio.h>
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#priority RDA,EXT
int32 gtemp1=1234567;
long int Delay_time=1000;
int Serial_1=0;
int Serial_2=0;
int RxFlag=0;
char RecvChar=null;
#int_rda
void rda_isr(void)
RecvChar = getc();
Delay_time = 100;
RxFlag = 1;
#int_ext
Void ext_isr(){
if(Delay_time==100)
Delay_time=1000;
Delay_time=100;
SET_TRIS_A(0b00000000);
SET_TRIS_B(0b10000001);
SET_TRIS_C(0b10000000);
Port_B_Pullups(TRUE);
ext_int_edge(0, L_to_H);
disable_interrupts(INT_TIMER0);
disable_interrupts(INT_TIMER1);
disable_interrupts(INT_TIMER2);
disable_interrupts(INT_TIMER3);
disable_interrupts(INT_EXT1);
disable_interrupts(INT_EXT2);
disable_interrupts(INT_RB);
disable_interrupts(INT_AD);
disable_interrupts(INT_TBE);
disable_interrupts(INT_RDA2);
disable_interrupts(INT_TBE2);
disable_interrupts(INT_CCP1);
disable_interrupts(INT_CCP2);
disable_interrupts(INT_EEPROM);
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
while(true){
gtemp1+=1;
// fprintf(SER1,"UART1A4=%d \r\n", input_state(TESTA4));
// fprintf(SER1,"UART1B0=%d \r\n", input_state(TESTB0));
fprintf(SER1,"UART1=%lu \r\n", gtemp1);
fputs("----------------",SER1);
if(RxFlag==1)
fprintf(SER1,"%c \r\n",RecvChar);
RxFlag   = 0;
output_bit(pin_b1,1);
// led=0b000000010;
delay_ms(Delay_time);
output_bit(pin_b1,0);
//   led=0b00000000;
//    Delay_time +=50;
Sad Sad
PostPosted: Wed Sep 25, 2013 7:52 pm     Reply with quote
What's your compiler version ? Always post it.
hwryu
PostPosted: Wed Sep 25, 2013 9:24 pm     Reply with quote
my compiler'version is 4.108
PostPosted: Wed Sep 25, 2013 10:55 pm     Reply with quote
See the fix shown at the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=43961
hwryu
PostPosted: Wed Sep 25, 2013 11:46 pm     Reply with quote
After following your advice, Rx interrupt is working well.
Thank you for your help. I am happy
