PIC16F720 FVR not working with ADC
picprogrammer12345
PostPosted: Fri Aug 09, 2013 1:51 pm     Reply with quote
Hello all,
I am using PIC16F720 for a project and I am not being able to use the Fixed voltage reference (FVR) or the PIC chip for reading the adc channels.
Below is the code:
#include <16F720.h>                               //The chip we are using
#use delay(clock=8000000)                         //set clock speed to 8Mhz
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#FUSES INTRC_IO,PLLEN,NOWDT,NOPUT,MCLR,PROTECT,NODEBUG
#byte  FVRCON     =  0x9D
   disable_interrupts(GLOBAL);
   FVRCON = 0xC2;
   set_tris_a(0xFF);
   set_tris_b(0xFF);
   set_tris_c(0xFF);
   setup_adc_ports(sAN5,VSS_FVR);
   setup_adc( ADC_CLOCK_INTERNAL);
   while(true)
         set_adc_channel(5);
      read_adc();
      printf("%u ", read_adc());
According to my understanding and reading multiple examples online, my code should enable the fixed voltage reference using the FVRCON register.
I have set appropriate bits high and set the reference at 2.048V.
Then I have set the adc channel 5 (AN5 or Pin C1) as analog and the voltage range from VSS to FVR.
I am feeding 1 volt into the adc channel 5.
Based on my understanding the ADC value reading should not change as long as the input is constant at 1V and the main PIC chip VDD is between 2.5 to 5 volts.
But, the ADC value keeps changing when I increase and decrease the main VDD to PIC. It seems like it is still referencing VDD as its higher voltage range and thus the 1 volt input adc value changes with the VDD change.
Am I missing something else on the code.
I have worked on it all day and cant seem to get it working.
Any help will be highly appreciated.
The compiler version I have is PCWH 4.129
PostPosted: Fri Aug 09, 2013 2:17 pm     Reply with quote
Start by using setup_vref, instead of writing to fvrcon.
setup_vref(VREF_2v048);
Your setting is trying to write a '1' to a read only bit. Probably not the problem, but shouldn't be done....
Then sequence to read the ADC, is always
1) Select channel.
2) wait Tacq
3) read channel.
You are not pausing at any point between selecting the channel and reading the adc....
The include file talks for a long time about the optional second argument, but on most compilers, it works better to OR the values together.
So:
setup_adc_ports(sAN5|VSS_FVR);
Worth trying this instead.
picprogrammer12345
PostPosted: Fri Aug 09, 2013 2:22 pm     Reply with quote
Tried it with
and also tried it with both
FVRCOn = 0xC2;
Also gave delay of 500ms after setting the channel.
No change. ADC value still changing when VDD is changed between 2.3 and 5 volts
picprogrammer12345
PostPosted: Fri Aug 09, 2013 2:23 pm     Reply with quote
FYI also tried it with
sAN5|VSS_FVR
PostPosted: Fri Aug 09, 2013 2:34 pm     Reply with quote
Study bit 7 of FVRCON. This is a read only bit.
I'd suspect your compiler has problems with this chip it was fairly new when this was supplied.
Grkan13
PostPosted: Tue Sep 24, 2013 1:14 pm     Reply with quote
I have the same problem with 16f721. Did you able to find a solution for that?
Thanks.
edit: compiler version 5.012
picprogrammer12345
PostPosted: Tue Sep 24, 2013 1:22 pm     Reply with quote
Yes,
I contacted ccs and they said that the function VSS_FVR is been placed by mistake in the .h file. PIC16F720 is incapable of setting fixed Vdd as FVR for the ADC pins.
It cannot be done on this chip.
Grkan13
PostPosted: Wed Sep 25, 2013 8:55 am     Reply with quote
Thank you picprogrammer12345
