array declaration
jhon
array declaration
PostPosted: Mon Sep 23, 2013 11:43 pm     Reply with quote
Hi
I want to assign values to the variable (6 variable). And then make array with this variable like given below.
int8 R_vtg = 0x01;
int8  Y_vtg = 0x02;
int8 B_vtg = 0x03;
int16 input_regs[]={ R_vtg,Y_vtg, B_vtg};
I know it is wrong but suggest me some way by which such array is formed.
PostPosted: Tue Sep 24, 2013 2:26 am     Reply with quote
I suggest getting a C textbook....
It is not at all obvious what you are trying to do. There is no such 'type of array' in C. It looks like you are trying to build an int16 array, containing other variables (which happen to be int8). An array is a variable in it's own right, it can't 'contain' other variables.
Possibly you are trying to construct an array of pointers?. If so then the array needs to be an array of pointers (not int16), and needs to be given the address of the variables, not the variables themselves.
