Maximum length for a name of a variable?
hello188
PostPosted: Thu Sep 12, 2013 11:25 pm     Reply with quote
Hi. what is the maximum variable name length for CCS-C compiler??
anyone tried?
PostPosted: Fri Sep 13, 2013 5:23 am     Reply with quote
I'd _think_ ,_maybe_ 255, though you should try it yourself and report back.
Frankly, I use SHORT names as they're easier to type, easier to read, and easier to retype when I misspell them ! Then again, I grew up on a BASIC that only allowed 2 character variables.....ah, the 'good old dayze'.
jay
PostPosted: Fri Sep 13, 2013 6:28 am     Reply with quote
I've never had the compiler complain about var_len.
And there is such an easy way to find out.
Have you tried it ?
Or put another way, are you an experimenter or not? Very Happy Very Happy Very Happy
PostPosted: Fri Sep 13, 2013 7:54 am     Reply with quote
Well you can tell I'm bored..cool,rainy,blaaa day here..
Did a simple test creating a char variable 26 characters long(every letter of the alphabet) and it was fine,kept doubling the length to 16 alphabets = 416 characters long..
..compiles just fine...
Sure wouldn't want to find a 'typo' in the variable name though!!
Jay
alan
PostPosted: Fri Sep 13, 2013 8:26 am     Reply with quote
Maybe so, but the compiler only recognise the 1st 64 character. If your name is longer than that you can mispell or just leave it out.
Regards
hello188
Thank you
PostPosted: Sun Sep 15, 2013 11:55 pm     Reply with quote
Thank you!!
Depicci
Re: Maximum length for a name of a variable?
PostPosted: Mon Sep 16, 2013 1:14 am     Reply with quote
You can try it if you have an output device or rs232 connection.
Create two variables for test
whatkindofsorceryisthis = '1'
whatkindofsorceryisthis2 = '2'
printf whatkindofsorceryisthis
if everything is ok extend variable name letter by letter and test it. The second variable should be different 'but just one letter' from the first one. When you obtain '2' as output, stop and count Smile
SherpaDoug
PostPosted: Mon Sep 16, 2013 5:54 am     Reply with quote
A BASIC compiler I used 35 years ago used the first six characters and the length of the variable name. It would have recognized whatkindofsorceryisthis2 as longer than whatkindofsorceryisthis.
PostPosted: Mon Sep 16, 2013 6:19 am     Reply with quote
You can tell I don't want to do real work....
...this works fine....
//global variables
24: char qwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnm=1;
25: char qqwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnm=2;
from the listing....
jay
PostPosted: Mon Sep 16, 2013 7:25 am     Reply with quote
The change needs to be at the _right end_ of the variable. Comparisons are done left to right.
   char qwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopaa=1;
   char qwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopab=2;
//Builds OK
   char qwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopasa=1;
   char qwertyuiopasdfghjklzxcvbnmqwertyuiopasdfghjklzxcvbnmqwertyuiopasb=2;
//doesn't
64 significant characters, as Alan says.
Worth also adding that this is 'per section' of the full variable name. So if you have a structure, there are 64 characters significant in the structure name, and then another 64 in the individual variables in the structure. Given that it is expansion of things like structures that is really likely to lead to OTT 'long names', it makes it very unlikely that it is ever going to cause a problem in use.
