AD595
MAKInnovation
AD595
PostPosted: Thu Sep 12, 2013 12:49 am     Reply with quote
Dear Friends;
I am confused to develop a formula for AD595 temperature measurement IC.
My Code is below:
#include <18F6722.h>
#DEVICE ADC=10
#fuses HS, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 10000000)
#include"D:\Drivers\Flex_LCDPORTF.C"
#use rs232 (baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
LONG RatioSel;
float temp;
set_tris_a(0XFF);
  setup_adc( ADC_CLOCK_DIV_8  );
  setup_adc_ports(ALL_ANALOG);
  int16 i;
  set_adc_channel(1);
  delay_us(100);
  RatioSel = read_adc();
   RatioSel = RatioSel * 1.25;
  lcd_gotoxy(1,3);
  printf(lcd_putc,"RatioSel: %ld        ",RatioSel);
I am using the resister devider circuit with 15K at IC side and 10K at ground side and middle pin is connected on analog pin of microcontroller.
when the temperature is 30C the value of the IC is 0.3 and ic read 0.12v on its analog pic because of devider circuit.
As per my understanding calculation would be
1023/5 * 0.12 * 1.25 = 30
Is it correct or please make me correct.
I dont know why i have to use "1.25" multiplier to make my result correct.
Also this formula does not work for the whole range from 0C to 1000C i required.
Can any one tell me the correct formula for temperature calculation using above hardware setting or suggest me any other correct option.
Regards
Ashraf
alan
PostPosted: Thu Sep 12, 2013 1:17 am     Reply with quote
Actually quite easy.
You are getting a digital value of 0.12*1024/5 = 24 (already inaccurate because it should be 24.7)
Now you need to convert it back to an "analog value" as that is what you're measurement are related to.
Vchip = (ADC * 5/1024) / (voltage divider) = 24 * 5/1024 * 25/10 = 0.293.
The output of your sensor are 10mV/Deg.
Temp = Vsensor / 0.01 = 29.3 should have been 30 but see top of post.
Thus your actual multiplier are 5/1024 * 25/10 * 1/0.01 = 1.221
Regards
Alan
PostPosted: Thu Sep 12, 2013 1:34 am     Reply with quote
Further comments though:
What is the minimum recommended source impedance for the ADC?. Does your divider meet this?. You need a buffer amplifier, or to use lower resistance values on the divider.
Then, don't set the channels as 'ALL_ANALOG', unless you are going to use all the analog channels. Each channel selected to the input multiplexer, potentially increases noise injected to the ADC. OK if the pins are connected to nice stable analog signals, but not if the pins are floating.
Then the big 'limit' on accuracy is using the power supply as Vref. Even with a good PSU, this will only be 1% 'accurate' at best, and _will_ have significant noise spikes on it as the CPU works. For high accuracy with low level signals, you need to be using a proper high precision Vref.
Remember also that simple resistors, will only typically be 1% at best accuracy....
MAKInnovation
PostPosted: Thu Sep 12, 2013 1:59 am     Reply with quote
Thank you friends
PostPosted: Thu Sep 12, 2013 8:46 am     Reply with quote
You CAN use Vdd as the reference supply with excellent results.
I have several heat control designs ( with 12bit A/Ds) where
Vdd is supplied by an LM317 from a 12V primary supply.
The "calibration" is preformed by fine adjustment of the LM317 divider pot.
works superbly well,
MAKInnovation
PostPosted: Thu Sep 12, 2013 11:34 pm     Reply with quote
Dear Asmboy;
Can you send me a complete schematic of heat c ontrol design on my email address
ctecd@yahoo.com
Ashraf
PostPosted: Sat Sep 14, 2013 3:44 pm     Reply with quote
the controller as a whole is a work 4 hire, so no will do.
but generically - this is what we I am talking about
http://www.circuitstoday.com/few-lm317-voltage-regulator-circuits
using a 100uf or greater tantalum cap on teh Vdd pin to Vss of the PIC dispenses with glitches very nicely and i use this for my a/d readings anyway:
http://www.ccsinfo.com/forum/viewtopic.php?t=50320&highlight=olympic
