What does RESTART_TRAP_CONFLICT cause mean?
stoyanoff
PostPosted: Mon Sep 09, 2013 12:35 am     Reply with quote
Greetings! I suppose it means my program reaches a point of dead trap or procedure where it can't get out. I want to be sure what to search for. Could anyone explain to me the meaning of this restart cause?
Thanks!
alan
PostPosted: Mon Sep 09, 2013 12:56 am     Reply with quote
See
http://www.ccsinfo.com/forum/viewtopic.php?t=45398
stoyanoff
PostPosted: Mon Sep 09, 2013 3:56 am     Reply with quote
OK! So how could I find the source of this restart?
Thanks!
PostPosted: Mon Sep 09, 2013 8:03 am     Reply with quote
Have a look at this:
<http://www.ccsinfo.com/forum/viewtopic.php?t=36479>
Shows how to implement an 'address error' trap. The same can be applied to other error types (there are links to some other examples).
Saves the address that _triggered_ the trap, so you can find out what is causing it.
stoyanoff
PostPosted: Mon Sep 09, 2013 11:59 pm     Reply with quote
I found the address - 2FA0. How can i find where in the program I'm using it, so I be able fix it???
Thanks!
PostPosted: Tue Sep 10, 2013 12:52 am     Reply with quote
Look in the .lst file, either physically, or with any debugger.
You should see what assembler is here, and what C instruction line generates this.
