haxan7
Reload file edited in external editor |
Posted: Fri Aug 30, 2013 3:32 am |
There is an option in ccs compiler (v4.140) that auto reloads project files edited in external editor.
I can't seem to find the settings.
Posted: Fri Aug 30, 2013 8:48 am |
Options
IDE
Dialogs
Open file was modified outside the IDE
If this is set, it gives you a warning, if not, it reloads automatically. |
haxan7
Posted: Fri Aug 30, 2013 9:14 am |
Ttelmah wrote: | Options
IDE
Dialogs
Can't find IDE under Options.
Posted: Fri Aug 30, 2013 9:55 am |
In V4, it does it automatically. In V5, it is changeable.
I thought you were complaining that it had worked in V4, and now didn't in V5....
It has always done it automatically in the older versions. When you save a file with an external editor, _provided you have the option 'recall open files' selected in the editor_.
alan
Posted: Fri Aug 30, 2013 10:55 am |
In V4 I had the same problem, suddenly not reloading a changed file. A reinstall did the trick, causing it to work again.
Regards |
