Bit banging SPI
congbinhdbk
Bit banging SPI
PostPosted: Tue Aug 27, 2013 9:18 pm     Reply with quote
Hi all!
I'm working with SPI by Software. I'm coding for slave with PIC18F4620 and have a problems. I receive data from master is ok but i can't transmit data from slave to master. Please help me!
int spi_io_read(int data_out) {
   int data_in=0;
   signed int i;
   sdo=0;
   for(i=7;i>=0;i--) {
      //set data to SDO
      if(bit_test(data_out,i)==1) sdo=1;
      else  sdo=0;
      //waiting for clock
      cnt=0;
      while((sck==0)&&(cnt<=100)) {
         cnt++;
      while((sck==1)&&(cnt<=200)) {
         cnt++;
      //read data in SDI
      if(sdi==1) bit_set(data_in,i);
      else bit_clear(data_in,i);
   return   data_in;
alan
PostPosted: Tue Aug 27, 2013 11:04 pm     Reply with quote
Your sample data on the opposite edge from writing data to the bus. This all depends on your setup. See http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus for full description.
You sample and write on the same edge.
Also much more efficient code to do it as below
for (i=0; i <8 ; i++) {
  if (bit_test(data_out,7) sdo=1;
  else sdo = 0;
  data_out <<=1;
Compiler can work out bit position at compile time instead of run time which involves more instructions.
Regards
Alan
PostPosted: Wed Aug 28, 2013 3:59 am     Reply with quote
Given that both the input byte, and output byte will be handling the same 'bit' at a time, I'd say it'd be more efficient, to use a single mask. So something like:
   int8 data_in=0;
   int8 mask=0x80; //MSb first
   sdo=0;
   do
      //wait for the first falling edge
      cnt=0;
      while((sck==1)&&(cnt<=100)) {
         cnt++;
      //set data to SDO
      if(data_out & mask) sdo=1;
      else  sdo=0;
      //read data in SDI
      if(sdi) data_in &=mask; //data_in is already zero, so you only need
      //to handle the 1's.
      //waiting for rising edge
      while((sck==0)&&(cnt<=200)) {
         cnt++;
      mask/=2;
   } while(mask); //finishes when eight bits transfered
   return   data_in;
However the big problem on the read, is that you are doing it a whole clock too late. Think about it. You preload the output value, then wait for a complete clock cycle, and read the input, and load the next output value. One bit late....
If your clock idles 'high', then the version I show will wait for the first falling edge, and then perform both transfers. However this will be the wrong way round if the clock idles low.
Using '/2' on the mask, codes as a rotation _through the carry_. So the bottom bit gets discarded each time, and after the eighth rotation, mask will be zero.
Bit_test, with a variable, is very inefficient. The compiler has to generate a mask, and rotate this the number of bits specified each time. Using your own single mask, just one rotation, for both bits.
