7 segment display
newCCSUser
7 segment display
PostPosted: Sun Aug 25, 2013 12:47 pm     Reply with quote
Hi.
I'm planning to implement 4x7 segment display on my pcb.
Did someone try to use some of the code from the code library for such design ?
PostPosted: Mon Aug 26, 2013 5:52 am     Reply with quote
You should reference the 'subject' or topic number for us to lookup. There are several 7 segment display topics, too many to sift through.
However, since it is in the code library, it is reasonable to conclude it does work...but...without seeing the code, I can't tell if it's for just common anode, common cathode or both types of displays.
hth
jay
wala.iswara
PostPosted: Mon Aug 26, 2013 8:33 pm     Reply with quote
I use code library just for reference and test the hardware.
What is your compiler version? Trying a number counter.
