Flex_LCD420 and Flex_KBD_4X3 SHARE SAME PORT
freedom
PostPosted: Thu Aug 22, 2013 9:44 am     Reply with quote
For reference of PCM Programmer
http://www.ccsinfo.com/forum/viewtopic.php?t=26229
Ok, Fantastic solution.
Thanks to PCM programmer.
I want to use port B of PIC16F877a for both LCD (4 x 20) & keypad (4x3). But If I want to use ICSP with those then what or how to do?
is this solution support driver Flex_LCD420.c and Flex_KBD_4X3.c ?
NOTE THAT I AM USING COMPILER VER. 4.124
PostPosted: Thu Aug 22, 2013 10:49 am     Reply with quote
Each of those drivers can be set to use any port you want. Just change the definitions.
PostPosted: Thu Aug 22, 2013 11:51 am     Reply with quote
Please read the PIC datasheet chapter on 'programming' or 'using ICSP'.
In there Microchip clearly details how to use both ICSP as well as 'user' interfaces.
hth
jay
freedom
PostPosted: Fri Aug 23, 2013 5:13 am     Reply with quote
Thanks Ttelmah to reply.
already I'm using those drivers.
My query is for using LCD and Keypad on same port at a time
As i post above link where showing a guide line to use LCD and Keypad on the same port at a time. That means same port shares both LCD and Keypad.
Now I want to use port B of PIC16F877a for both LCD (4 x 20) & keypad (4x3) at a time.
does this solution support driver Flex_LCD420.c and Flex_KBD_4X3.c ?
freedom
PostPosted: Sat Aug 24, 2013 12:50 am     Reply with quote
PostPosted: Sat Aug 24, 2013 1:18 am     Reply with quote
You are going the way to getting a bad reputation, running two threads on the same question.....
Yes, you can combine the two drivers onto one port.
PCM programmer gives 'how'.
However _caveat_. When a key is pressed, you cannot write to the LCD. Also, certain patterns of three keys, will cause problems, unless there are diodes on the key drive lines.
However you'll not blow up the PIC, unless you do something silly like connecting 5v directly to an output (even then it'll often survive), or having long lengths of unshielded wire to the keypad.
Basically, once the LCD 'enable' line is off, the remaining signals can be used to control a keypad. To do the job 'better', ideally the four input lines should feed to the PIC via 'AND' gates, with the other input of each gate connected to the signal that feeds the LCD enable. This then means that when the LCD is 'on', the keypad is disconnected. You'd then need separate pull up resistors where these lines connect to the gates, and diodes on the drive lines.
Done like this, the LCD will still work, when keys are pressed. Otherwise if keys are held, the LCD can't work.
