Help me with a TMR0 PWM ADC problem
souyirouh
PostPosted: Tue Aug 13, 2013 11:45 am     Reply with quote
I'm trying to do a PWM control for a servo so i end up doing it with the TMR0 cause in my opinion is the most exactly but i don't know exactly what is the problem with my program. It doesn't show any error and the logic behind it is good or at least i think so, anyway when i try to simulate it in Proteus it doesn't send the PWM signal, the TMR0 interrupt should appear each 0.1 that's why i put set_timer0(6) . I hope someone could help me here.
#include <16f877.h>
#device adc=10
#fuses HS,NOWDT,PUT,NOPROTECT,NOLVP,NOBROWNOUT,NOWRT
#define MAX_VALUE 200
#int_TIMER0
int pulse_max=0;
int16 adc=0,pulse_top=10; //min
void TIMER0_isr(void) {
if (pulse_max<=pulse_top)
   output_high(PIN_B0);
   output_low(PIN_B0);
if (pulse_max>=MAX_VALUE)
   pulse_max=0;
pulse_max++;
set_timer0(6);
void main(){
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
set_timer0(6);
setup_adc_ports(AN0);
for(;;){
  set_adc_channel(0);
  delay_us(20);
  adc=read_adc();
  pulse_top=(10*adc+10230)/1023;
  //x= (max-min)adc + 1023*min )/1023
PostPosted: Tue Aug 13, 2013 12:35 pm     Reply with quote
#int_TIMER0
int pulse_max=0;
Read this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=46477&start=4
souyirouh
PostPosted: Tue Aug 13, 2013 12:58 pm     Reply with quote
GOD BLESS YOU MAN !!!!!
PCM programmer wrote:
#int_TIMER0
int pulse_max=0;
Read this post:
