Lykos1986
HMC5883L Convert to heading |
Posted: Fri Aug 02, 2013 10:41 am |
Hi! I was writing a driver for the HMC5883L in order to get heading readings in degrees.
So far I am getting back X,Y,Z magnitude values and I am storing them into three (compass_x, compass_y, compass_z) signed int16 variables. The gain is set to 1.3.
It seems that so far everything is working great!
Now, I want to convert those into heading in degrees (in order to have a 0 - 360 result). I was searching the web and found the regular atan(Y/X) formula. Together with that I am correcting the output value when I am having negative results. Something like:
compass_x = (X_MSB << 8) | X_LSB;
compass_y = (Y_MSB << 8) | Y_LSB;
compass_z = (Z_MSB << 8) | Z_LSB;
head = atan((float)compass_y/(float)compass_x);
if(head < 0.0)
head += 2*PI;
Heading_Degrees = head * 180.0/3.14159;
head and Heading_Degrees are float variables. The problem is that the output results are totally wrong! I am getting 0.0 for almost a quarter rotation, then it jumps to 45 then it tracks (almost perfect) from 210 to 345...
Any info of what is going wrong? Maybe the formula? The variable types are wrong? |
Posted: Fri Aug 02, 2013 1:09 pm |
This type of problem can be completely tested in MPLAB simulator with
numeric output displayed in the MPLAB Output Window. You go into the
MPLAB Debugger menu and setup UART1 to redirect printf's (etc) to the
Output Window. It's a just a pure math problem and/or coding problem.
The first thing to do is, make your code snippet into a short compilable
test program. Put in the #include, #fuses, #use delay, main(), variable
declarations, #include for math library routines, etc. And put in printf
statements at the end to display the results of the calculations.
Then at the beginning of main(), load X_MSB, X_LSB, etc., with values
that you know are causing the problem. You didn't tell us what those are.
Run the program in MPLAB Simulator (make sure you have it set for the
correct PIC in the Configure/Select Device menu). Then post the results
that you see in the Output window. Also post what you expect it to be.
For sure, remember to post your CCS compiler version. |
Posted: Sat Aug 03, 2013 4:32 am |
No guarantees on this, and you need to work out what is causing your problems first, but this is an alternative to using atan for this problem.
It is a generic function, that accepts an X and Y co-ordinate, and returns the corresponding angle in degrees.
I may well have got the quadrant solutions wrong, but a quick test suggests it looks right. The accuracy is better than half a degree, and it is _fast_. Takes about 70uSec on a 40Mhz PIC, while atan takes at least ten times longer. It is also smaller.... It only gives positive angles, from 0 to 360 as it's result.
//Processor defines here....
#include <math.h>
float angle(float X, float Y)
//routine to give a fast solution for angle, from X/Y co-ordinates - result in degrees
float AX,AY,ival,oval,aival;
int8 quad;
AX=fabs(X);
AY=fabs(Y);
//Now the approximation used works for tan from -1 to 1, so we have to keep the
//values inside this range and adjust the input/output.
//Four 'quadrants' are decoded -1 to 1, (315 to 45 degrees), then 45 to 135,
//135 to 225, 225 to 315
If (X >= 0) //Right hand half of the circle
If (AY > X)
If (Y < 0)
quad = 4;
ival = -X / Y;
Else
quad = 2;
ival = X / -Y;
Else
If (AY > X)
quad = 4;
ival = -Y / X;
quad = 1;
ival = Y / X;
//Now the others
If (Y > AX)
quad = 2;
ival = X / -Y;
Else
If (AY > AX)
quad = 4;
ival = -X / Y;
Else
quad = 3;
ival = -Y / -X;
//A lot of lines of code, but small and quick really.....
//Now the solution
//Now approximation for atan from -1 to +1, giving an answer in degrees.
aival = fAbs(ival);
oval = 45 * ival - ival * (aival - 1) * (14.02 + 3.79 * aival);
//Now solve back to the final result
If (quad != 1)
If (quad == 2)
oval = oval + 90;
Else
If (quad == 3)
oval = oval + 180;
Else
oval = oval + 270;
if (oval<0)
oval+=360;
return oval;
//Demo program using pairs of numbers from the array to test
const signed int16 source[] = {0,300,600,1000,0,-300,-600,-1000};
int8 ctr,ctr2=0;
signed int16 X,Y;
while (TRUE)
for (ctr=0;ctr<8;ctr++)
//Now loop through the array, using pairs from two counters as X/Y
X=source[ctr];
Y=source[ctr2];
printf("X %ld, Y %ld, angle %5.1f\n\r", X,Y,angle(X,Y));
if (ctr2<7)
ctr2++;
ctr2=0;
dorinm
Posted: Sat Aug 03, 2013 5:41 pm |
excellent! |
RF_Developer
Posted: Mon Aug 05, 2013 2:42 am |
The function atan2(y, x) is intended for just this sort of problem, but if the approximation works accurately enough then use it. |
Posted: Mon Aug 05, 2013 4:08 am |
The approximation is more accurate than the chip. It's about half the size in ROM.
The maximum error, for the entire range of the chip output (-2047 to 2048), is under 0.1 degrees.
As a comment though, using atan, could be the reason for the original problems. atan2, is specifically written to 'cope' with the special cases where X=0, while a division, feeding atan, will return a maths error, which unless trapped, will result in garbage results. The approximation also handles this case.
