dspic30f5011 Programming error!
harvester
PostPosted: Thu Jul 18, 2013 5:07 am     Reply with quote
hi, my friends..
i am a newbie on dspic series, i have successfully programmed many 16F and 18F families pics, but i am currently using dspic30f5011. when i programmed and write to dspic30f2010 or 4013, all is fine, but i am not able to program dspic30f5011 in the same way. i am using pickit3 and CCS C 4.068 as the compiler. In data sheet, it is mentioning about somethings more must be done but i don't get it. what else am i supposed to do? all i do is...
1-write the code and create hex file
2- Load the hex file via pickit3
3- run the processor
Best Regards!
