parthiv2eng
[SOLVED] UART and External Clock - PIC18F25k20 |
Posted: Wed Jul 17, 2013 1:08 pm |
I am using pic18f25k20 with external oscillator. The problem is my UART transmit works fine but when it comes to receiving it won't receive proper data or skips data.
If I use internal clock. everything works fine like charm.
/*! Include Section: (Library Files)
#include <18F25K20.h>
/*! Device bit configuration
#device *=16 ICD=TRUE // Use 16 bit pointers, enable ICD
#device adc=10
#FUSES WDT //WDT128 //NOWDT //Use Watch Dog Timer
#FUSES EC_IO //External Clock
//#FUSES INTRC //Internal RC Osc
#FUSES PROTECT //NOPROTECT //Code not protected from reading
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
//#use delay(clock=16000000) //clock for the delay 16 MHz
#use delay(osc=3686400) //Assiegn oscillator
//! Initialize UART
#use rs232(baud=115200, parity = o,xmit=PIN_C6, rcv=PIN_C7,errors) //!Initialize UART
My external osc frequency 3.6864Mhz and measured using scope. Please guide me. Any comment is appreciated. Thanks!
Posted: Wed Jul 17, 2013 3:25 pm |
You just not clocking fast enough.....
3.7MHz. Just 0.925MIPS. 115200bps. One character every 80 instructions. If you are (for instance) using interrupt driven serial, it takes typically 60 instructions, just to get into and out of the interrupt handler. Add the time to store the data (if you are using an array, it takes quite a few instructions to access each location), and you are just running out of time....
Transmit doesn't have a problem, since if the processor can't keep up, there will just be gaps between the characters. Also you are doing the transmit, rather than the characters arriving 'unprompted' as they do on the receive.
If you can lose the OSC1 pin, just select HSPLL, instead of EC_IO, and run at 14745600Hz. Otherwise switch to a faster oscillator.
parthiv2eng
Posted: Wed Jul 17, 2013 4:08 pm |
Quote: |
If you can lose the OSC1 pin, just select HSPLL, instead of EC_IO, and run at 14745600Hz. Otherwise switch to a faster oscillator. |
In PIC18F25k20
Fuses: LP,XT,HS,RC,EC,EC_IO,H4,RC_IO,INTRC_IO,INTRC,NOFCMEN,FCMEN
I don't get it how to turn PLL on for External Clock.? |
Joined: 01 Jul 2010 Posts: 9228 Location: Greensville,Ontario
Posted: Wed Jul 17, 2013 6:48 pm |
Can you also confirm that you need 'odd' parity ? Most 8 bit UART data transfers have 'none' selected for parity.
Having the wrong parity could cause 'data problems'.
I know some products have 'interesting' or 'nonstandard' settings, just thought I'd ask.
hth
jay |
parthiv2eng
Posted: Wed Jul 17, 2013 10:00 pm |
temtronic,
Thanks for reply. The problem is data receiving by UART using "External Clock". When I use internal clock everything seems working fine. |
Posted: Thu Jul 18, 2013 12:43 am |
H4
However this will switch to HS PLL (*4), not 'external clock'. Generally it'll work fine with a clock fed into the input pin (though you may need to add a series resistor to avoid over-driving the input). However you lose the oscillator output pin.
parthiv2eng
Posted: Mon Jul 29, 2013 4:33 pm |
Thanks Ttelmah,
Still it won't work.. |
parthiv2eng
Posted: Tue Aug 27, 2013 10:39 am |
Sorry for Late reply,
Ttelmah, It's working with H4 using external clock.
Thank you all |
