Help to make driver of MX25L6445E
kongfu1
PostPosted: Fri Jul 12, 2013 8:38 pm     Reply with quote
Somehow a driver of MX25L6445E is not working. Please help.
CCS 4.144
PIC24EP512GU810
#define  TRANS_LENGTH  16
#define  RANDOM_SEED   106
#define  FLASH_TARGET_ADDR  0x00000000
uint32 FlashID = 0xc2201700;
uint8 ElectronicID = 0x16;
void SendFlashAddr( uint32 flash_address)
    spi_write( flash_address >> 24 ); // A31-A0
    spi_write( flash_address >> 16 );
    spi_write( flash_address >> 8 );
    spi_write( flash_address );
//enable write bit
ReturnMsg CMD_WREN( void )
    // Chip select go low to start a flash command
    output_low(FLS_MEM_CS);
    // Write Enable command = 0x06, Setting Write Enable Latch Bit
    spi_write( FLASH_CMD_WREN );
    // Chip select go high to end a flash command
    output_high(FLS_MEM_CS);
    return FlashOperationSuccess;
//page program
ReturnMsg CMD_PP( uint32 flash_address, uint8 *source_address, uint32 byte_length )
    uint32 index;
    uint8  addr_4byte_mode;
    // Check flash is busy or not
    if( IsFlashBusy() )    return FlashIsBusy;
    // Check 3-byte or 4-byte mode
    addr_4byte_mode = TRUE;  // 4-byte mode
    // Setting Write Enable Latch bit
    CMD_WREN();
    // Write Page Program command
    spi_write( FLASH_CMD_PP );
    SendFlashAddr( flash_address );
    // Set a loop to down load whole page data into flash's buffer
    // Note: only last 256 byte will be programmed
    for( index=0; index < byte_length; index++ )
        spi_write( *(source_address + index) );
    if( WaitFlashReady( 2000 ) )
        return FlashTimeOut;
//erase flash
ReturnMsg CMD_SE( uint32 flash_address )
    CMD_WREN();
    //Write Sector Erase command = 0x20;
    spi_write( FLASH_CMD_SE );
    if( WaitFlashReady( 5000 ) )
//read Status Register Bits.
ReturnMsg CMD_RDSR( uint8 *StatusReg )
    uint8  gDataBuffer;
    // Send command
    spi_write( FLASH_CMD_RDSR );
    gDataBuffer = spi_read( 0 );
    *StatusReg = gDataBuffer;
//read flash
ReturnMsg CMD_READ( uint32 flash_address, uint8 *target_address, uint32 byte_length )
    uint32 index;
    // Write READ command and address
    spi_write( FLASH_CMD_READ );
    // Set a loop to read data into buffer
        // Read data one byte at a time
        *(target_address + index) = spi_read( 0 );
//read mfg id
ReturnMsg CMD_RDID( uint32 *Identification )
    uint32 temp;
    uint8  gDataBuffer[3];
    // Send command
    spi_write( FLASH_CMD_RDID);
    // Get manufacturer identification, device identification
    gDataBuffer[0] = spi_read( 0 );
    gDataBuffer[1] = spi_read( 0 );
    gDataBuffer[2] = spi_read( 0 );
    // Chip select go high to end a command
    // Store identification
    temp =  gDataBuffer[0];
    temp =  (temp << 8) | gDataBuffer[1];
    *Identification =  (temp << 8) | gDataBuffer[2];
//read electronic ID
ReturnMsg CMD_RES( uint8 *ElectricIdentification )
    // Send flash command and insert dummy cycle
    spi_write( FLASH_CMD_RES);
    //Insert Dummy Cycle - 24 bits
    spi_read(0);
    spi_read(0);
    spi_read(0);
    // Get electric identification
    *ElectricIdentification = spi_read(0);
BOOL IsFlashBusy( void )
    uint8  gDataBuffer;
    CMD_RDSR( &gDataBuffer );
    if( (gDataBuffer & FLASH_WIP_MASK)  == FLASH_WIP_MASK )
        return TRUE;
        return FALSE;
BOOL WaitFlashReady( uint32 ExpectTime )
    uint32 temp = 0;
    while( IsFlashBusy() )
        if( temp > ExpectTime )
            return FALSE;
        temp = temp + 1;
        delay_ms(1);
    return TRUE;
uint8 FlashID_Test( void )
    uint32  flash_id = 0;
    uint16  error_cnt = 0;
    uint16  rems_id;
    uint8   electric_id = 0;
    FlashStatus  flash_state = {0};
    ReturnMsg  msg;
    /* Read flash device id */
    msg =  CMD_RDID( &flash_id );
    if( msg != (ReturnMsg)FlashOperationSuccess )
        return FALSE;
    msg = CMD_RES( &electric_id );
        return FALSE;
   /* Compare to expected value */
    if( flash_id != FlashID )
        return FALSE;
    if( electric_id != ElectronicID )
        return FALSE;
    return TRUE;
uint8 FlashReadWrite_Test( void )
    ReturnMsg  message= 0;
    uint32  flash_addr;
    uint32  trans_len = 0;
    uint16  i=0, error_cnt = 0;
    uint16  seed = 0;
    uint8   st_reg = 0;
    uint8   memory_addr[TRANS_LENGTH] = {0};
    uint8   memory_addr_cmp[TRANS_LENGTH] = {0};
    /* Assign initial condition */
    flash_addr = FLASH_TARGET_ADDR;
    trans_len = TRANS_LENGTH;
    seed = RANDOM_SEED;
    /* Prepare data to transfer */
    srand( seed );
    for( i=0; i< trans_len; i=i+1 ){
        memory_addr[i] = rand()%256;   // generate random byte data
    /* Erase 4K sector of flash memory
       Note: It needs to erase dirty sector before program */
    CMD_SE( flash_addr );
    /* Program data to flash memory */
    CMD_PP( flash_addr, memory_addr, trans_len );
    /* Read flash memory data to memory buffer */
    CMD_READ( flash_addr, memory_addr_cmp, trans_len );
    /* Compare original data and flash data */
    for( i=0; i < (trans_len); i=i+1 )
        if( memory_addr[i] != memory_addr_cmp[i] )
            error_cnt++;
    /* Erase 4K sector of flash memory */
    if( error_cnt != 0 )
        return FALSE;
        return TRUE;
void initFSHMem(void)
   uint8 theRet;
   BOOL theBool;
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_512);
   theBool = WaitFlashReady( 1000 );
   if(theBool)
      theRet = FlashReadWrite_Test();
      //theRet = FlashID_Test();
Thanks.
PostPosted: Fri Jul 12, 2013 9:43 pm     Reply with quote
Check your code. For SPI applications, the first thing to check is your
setup_spi() statement:
Here are the #define statements for the SPI modes:
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
Now you should look in the MX25L6445E data sheet, at the following
figure, and see what SPI modes it supports:
Figure 1-1. Serial Modes Supported (for Normal Serial mode)
Compare that to the mode in your setup_spi() statement.
