PIC16LF1509 CLC3/4 responding [solved]
kunzem
PostPosted: Fri Jul 12, 2013 5:53 am     Reply with quote
Hello, I'm trying to work with the CLC's of the PIC, the cells 1 and 2 are working fine and as expected, but 3 and 4 are not responding in any way.
compiler is: CCS PCM C Compiler, Version 5.007, 10594
I'm using following test code that is an and/or with high on all ins and should give also an high output:
   clc2_setup_input(1,CLC_INPUT_3);
   clc2_setup_input(2,CLC_INPUT_0);
   clc2_setup_input(3,CLC_INPUT_7);
   clc2_setup_input(4,CLC_INPUT_7);
   clc2_setup_gate(1,CLC_GATE_SET);
   clc2_setup_gate(2,CLC_GATE_SET);
   clc2_setup_gate(3,CLC_GATE_SET);
   clc2_setup_gate(4,CLC_GATE_SET);
   setup_clc2(CLC_ENABLED | CLC_MODE_AND_OR);
   clc3_setup_input(1,CLC_INPUT_3);
   clc3_setup_input(2,CLC_INPUT_0);
   clc3_setup_input(3,CLC_INPUT_7);
   clc3_setup_input(4,CLC_INPUT_7);
   clc3_setup_gate(1,CLC_GATE_SET);
   clc3_setup_gate(2,CLC_GATE_SET);
   clc3_setup_gate(3,CLC_GATE_SET);
   clc3_setup_gate(4,CLC_GATE_SET);
   setup_clc3(CLC_ENABLED | CLC_MODE_AND_OR);
1 and 4 are configured exactly the same way.
and for check this one:
 while (1) {
           l1 = LC1OUT;
           l2 = LC2OUT;
           l3 = LC3OUT;
           l4 = LC4OUT;
           printf("%u %u %u %u \n",l1,l2,l3,l4);
           delay_ms(50);
this only works as expected for CLC1 and 2:
1 1 0 0
1 1 0 0
1 1 0 0
1 1 0 0
1 1 0 0
i already crawled the web, docs and also the generated assembly... cant find any reason why they play dead duck... (oh also changed the chip 2 times)
also does anyone have an idea how to transform a 22khz signal to a steady one with one logic cell? i got a 22khz single pulse signal on pwm for that purpose but its not synced to the input signal, so the approach is this:
clc1 is setting flip flop on high signal of the input and resetting on pwm pulse, clc2 is just a d-flipflop that latches on pwm signal, this gives an steady information if 22khz is on or off (diseqc decoding)
kunzem
PostPosted: Fri Jul 12, 2013 8:43 am     Reply with quote
apparently its a bug in the LC3OUT/LC4OUT definition cause:
enable output to pin works, signal is on pin
and also reading the value like this for CLC3 works:
#byte c3con = 0xF20
lc3out = c3con & 0x32;
kunzem
PostPosted: Fri Jul 12, 2013 9:10 am     Reply with quote
solved with updated header file for chip, thanks ccs
