prafulla.prolific
Help For Serial communication & Phase Angle Control |
Posted: Fri Jun 28, 2013 1:49 am |
I want to communicating with two PIC 16F873A with RS485. Master containing keys & Slave Contain Zero detect & Phase Control. I have written program from Master as if key1 press it send data if key 1 pressed contionuosly upto 5 Sec then data changes from 170 to 240. & if key2 pressed contionuosly upto 5 Sec then data changes from 240 to 170. and data send from master after each count value changes. and on Reciever Side It Recieve data and after Zero cross detect generate phase angle delay (put recieve value on TIMER 0 t )to give Pulse to MOC3023. But I had checked it cant control. I Cant, understand where is problem can any guide me.
my Code as
//SLAVE CODE
#include <rs485.c>
#include <stdlib.h>
#use rs232(xmit=PIN_C6,rcv=PIN_C7,enable=PIN_B0,baud=9600)
#define MINIMUM_FIRING_ENGLE 170
#define MAXIMUM_FIRING_ENGLE 230
#byte PortB = getenv("SFR:PortB")
void initialize_ports(void);
void initialize_variables(void);
unsigned int8 fire_on_delay;
unsigned int8 firing_angle;
unsigned int1 TRAIC_GATE;
int8 count;
#int_RB
void RB_isr(void) // Zero Cross Detect _ to Pin RB5
int8 current;
static int last=0;
TRAIC_GATE=1;
set_timer0(firing_angle);
enable_interrupts(INT_TIMER0); //Enable timer0 interrupt
set_tris_b(0xF0);
current=input_b();
last=current;
#int_TIMER0
void TIMER0_isr(void)
disable_interrupts(INT_TIMER0); //disable timer0 interrupt
if(TRAIC_GATE)
output_low(PIN_A2);
TRAIC_GATE=0;
set_timer0(fire_on_delay);
else if(!TRAIC_GATE)
output_high(PIN_A2);
TRAIC_GATE=1;
port_b_pullups(TRUE);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
// setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
TRAIC_GATE=0;
count= 170;
initialize_ports();
initialize_variables();
enable_interrupts(INT_RB);
// enable_interrupts(INT_TIMER0);
count= getc();
delay_ms(600);
output_low(PIN_A0);
output_low(PIN_A1);
output_float(PIN_A3);
output_float(PIN_A4);
output_float(PIN_A5);
// output_high(PIN_C0);
// output_float(PIN_C1);
// output_high(PIN_C2);
// output_float(PIN_C3);
// output_float(PIN_C4);
output_high(PIN_B5);
firing_angle = count;
fire_on_delay= 400-firing_angle;
Master Code
#define MINIMUM_FIRING_ANGLE 170
#define MAXIMUM_FIRING_ANGLE 240
#define CH1_UP 0x0a
#define CH1_DOWN 0x0b
void initialise_ports(void);
int8 chk_status(void);
unsigned int8 last_fire_value;
int8 ScanKeys(void)
/* union {
struct {
int1 key1;
int1 key2;
int1 key3;
int1 key4;
int1 key5;
int1 key6;
int1 key7;
int1 key8;
} s;
int8 b;
} keys;
keys.s.key1 = input(PIN_KEY1);
keys.s.key2 = input(PIN_KEY2);
keys.s.key3 = input(PIN_KEY3);
keys.s.key4 = input(PIN_KEY4);
keys.s.key5 = input(PIN_KEY5);
keys.s.key6 = input(PIN_KEY6);
keys.s.key7 = input(PIN_KEY7);
keys.s.key8 = input(PIN_KEY8);
delay_ms(50); //debounce keys
if(keys.s.key1 != input(PIN_KEY1))
keys.s.key1 = ~keys.s.key1;
if(keys.s.key2 != input(PIN_KEY2))
keys.s.key2 = ~keys.s.key2;
if(keys.s.key3 != input(PIN_KEY3))
keys.s.key3 = ~keys.s.key3;
if(keys.s.key4 != input(PIN_KEY4))
keys.s.key4 = ~keys.s.key4;
if(keys.s.key5 != input(PIN_KEY5))
keys.s.key5 = ~keys.s.key5;
if(keys.s.key6 != input(PIN_KEY6))
keys.s.key6 = ~keys.s.key6;
if(keys.s.key7 != input(PIN_KEY7))
keys.s.key7 = ~keys.s.key7;
if(keys.s.key8 != input(PIN_KEY8))
keys.s.key8 = ~keys.s.key8;
return(keys.b);*/
unsigned int8 key_data;
unsigned int8 dimming_value;
dimming_value=last_fire_value;
key_data=chk_status(); //key_detection
if(key_data != 0xFF)
delay_ms(20); // Debounce
output_low(PIN_C3);
key_data=chk_status(); //Key_confirmation
if(key_data == 0xfb)
output_toggle(PIN_C3);
if(last_fire_value < 240)
dimming_value++;
dimming_value=240;
if(key_data == 0xf7)
if(last_fire_value > 170)
dimming_value--;
dimming_value=170;
last_fire_value =dimming_value;
return(dimming_value);
int8 PrevResult, CurrResult;
setup_adc(ADC_OFF);
setup_vref(FALSE);
last_fire_value=MINIMUM_FIRING_ANGLE;
PrevResult = ScanKeys();
CurrResult = ScanKeys();
if(CurrResult != PrevResult)
PrevResult = CurrResult;
void itialise_ports(void)
output_high(PIN_A0);
output_high(PIN_A1);
output_high(PIN_A3);
output_high(PIN_A4);
output_high(PIN_A5);
output_low(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C3);
output_high(PIN_B4);
int8 temp;
temp=((input_B()<<2) & 0xC0);
temp=((input_A() & 0x3F) | temp);
return temp;
Please Guide us what steps i want to follows if any guide me i will very appreciating.
Prafulla _________________ I m Working as PIC Programmer Fresher |
Mike Walne
Posted: Fri Jun 28, 2013 2:33 am |
Break the problem into bite sized chunks.
The posted code is not complete and compilable, so we can't copy and paste to test.
You're very vague about what works and what does not, we have to guess.
Mike |
Joined: 01 Jul 2010 Posts: 9165 Location: Greensville,Ontario
Posted: Fri Jun 28, 2013 5:47 am |
Mike is right..
I'd get rid of the 'master' code, RS485, etc. Put everything into the 'slave' and get it up and running.
Put in say a table of firing angles (every 10*) and cycle through them in 5 second intervals to confirm the phase control is properly working. Once that's done then work on the keypad interface (but in the same PIC). Again, confirm it works them merge the two. Confirm that works...
THEN
..split the program in half where the master scans the keypad and sends the slave the command.
You've got way too much going on to figure out what's busted.
also whenever using the hardware UART, always add 'errors' to the use rs232('''options....")
hth
jay |
beating a tired dog ?? |
Posted: Fri Jun 28, 2013 12:46 pm |
Haven't we been through the bulk of this problematic code already with :
http://www.ccsinfo.com/forum/viewtopic.php?p=176948&highlight=#176948
If you can't do RS-485 - GET rid of all the messed up zero cross and other unrelated overburden - and just show a short program that features your new problem.
The attempt at "TRAIC" control is in the same state of repair and function as back them and only adds to the confusion.
SIMPLIFY please |
