Help for PIC to PIC Communication using RS485
prafulla.prolific
PostPosted: Mon Jun 24, 2013 2:04 am     Reply with quote
I am having problem in RS485 communication I have written my code with the help of example but i have problem. My hardware is ok having PIC 16F873A, 6 Keys & Max 485 IC .
my code as
#include<rs485.c>
#define RS485_ID  OUR_RS485_ID
#define MINIMUM_FIRING_ENGLE   150
#define MAXIMUM_FIRING_ENGLE   240
#define CH1_ON   0x01
#define CH1_OFF  0x02
#define CH2_ON   0x03
#define CH2_OFF  0x04
#define CH3_ON   0x05
#define CH3_OFF  0x06
unsigned int1 ch_on;
int8 OUR_RS485_ID = 0;
 void initialise_ports(void);
int8 chk_status(void);
unsigned int8 key_data;
unsigned int8 dimming_value;
#int_TBE
void  TBE_isr(void)
   putc(dimming_value);
#int_TIMER1
void  TIMER1_isr(void)
//   int8 i;
//   if(rs485_get_message(msg, FALSE))
//      printf("\n\r%d: ", msg[0]);
//      for(i=0; i < msg[1]; ++i)
//         putc(msg[i+2]);
//      printf("\n\r");
#int_TIMER0
void  TIMER0_isr(void)
   unsigned int8 dimming_ch1;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
   setup_vref(FALSE);
   SET_TRIS_A(0x3F);
   initialise_ports();
//   enable_interrupts(INT_TIMER1);
//   enable_interrupts(INT_TIMER0);
//   enable_interrupts(INT_TBE);
//   enable_interrupts(GLOBAL);
   key_data=0xff;
      key_data=chk_status();
      if(key_data != 0xFF)
        delay_ms(10);
        if(key_data == 0xfe)
            output_high(PIN_C0);
            ch_on=1;
            dimming_value=CH1_ON;
//            disable_interrupts(INT_TBE);
            while(! input(PIN_A0));
        if(key_data == 0xfd)
            output_low(PIN_C0);
            ch_on=0;
            dimming_value=CH1_OFF;
            while(! input(PIN_A1));
        if(key_data == 0xef)
            output_high(PIN_C1);
            dimming_value=CH2_ON;
            while(! input(PIN_A4));
        if(key_data == 0xdf)
            output_low(PIN_C1);
            dimming_value=CH2_OFF;
            while(! input(PIN_A5));
        if(key_data == 0xbf)
            output_high(PIN_C2);
            dimming_value=CH3_ON;
            while(! input(PIN_B4));
        if(key_data == 0x7f)
            output_low(PIN_C2);
            dimming_value=CH3_OFF;
            while(! input(PIN_B5));
        if(ch_ON)
            if(key_data == 0xfb)
               while(!input(PIN_A2));
                  if(dimming_ch1 < 238)
                     dimming_ch1++;
                     dimming_ch1 = 240;
                  dimming_value=dimming_ch1;
                  delay_ms(40);
                  output_toggle(PIN_C3);
            if(key_data == 0xf7)
               while(! input(PIN_A3));
                  if(dimming_ch1 > 152)
                     dimming_ch1--;
                     dimming_ch1 = 150;
                  delay_ms(40);
     key_data=0xff;
   }//end_of_while
   output_high(PIN_A0);
   output_high(PIN_A1);
   output_high(PIN_A2);
   output_high(PIN_A3);
   output_high(PIN_A4);
   output_high(PIN_A5);
   output_low(PIN_C0);
   output_low(PIN_C1);
   output_low(PIN_C2);
   output_float(PIN_C3);
   output_high(PIN_B4);
   output_high(PIN_B5);
   int8 temp;
   temp=((input_B()<<2) & 0xC0);
   temp=((input_A() & 0x3F) | temp);
   return temp;
void init_variable(void)
//   MAXIMUM_FIRING_ENGLE;
void RS485send(char* s, int8 id)
   int8 size;
   for(size=0; s[size]!='\0'; ++size);
   rs485_wait_for_bus(FALSE);
   while(!rs485_send_message(id, size, s))
      delay_ms(OUR_RS485_ID);
can any help me please just guide me i will follow guideline.
I m Working as PIC Programmer Fresher
prafulla.prolific
Re: Help for PIC to PIC Communication using RS485
PostPosted: Mon Jun 24, 2013 3:52 am     Reply with quote
my code as
#include<rs485.c>
#define CH1_ON   0x01
#define CH2_ON   0x03
#define CH3_ON   0x05
#int_TBE
void  TBE_isr(void)
#int_TIMER1
//   int8 i;
//         putc(msg[i+2]);
//      printf("\n\r");
#int_TIMER0
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
   SET_TRIS_A(0x3F);
   initialise_ports();
   key_data=0xff;
        delay_ms(10);
            ch_on=1;
            output_low(PIN_C0);
            ch_on=0;
            output_low(PIN_C1);
            output_low(PIN_C2);
        if(ch_ON)
                     dimming_ch1++;
                     dimming_ch1 = 240;
                  delay_ms(40);
                     dimming_ch1--;
                     dimming_ch1 = 150;
                  delay_ms(40);
     key_data=0xff;
   }//end_of_while
   output_low(PIN_C0);
   output_low(PIN_C1);
   output_low(PIN_C2);
   int8 temp;
   return temp;
   int8 size;
schematic for circuit as follow.
[img]http://postimg.org/image/3lh0mj333/[/img]
[img][/img]
PostPosted: Mon Jun 24, 2013 5:42 am     Reply with quote
'it doesn't work'...is not very helpful..
Please breakdown your program into smaller steps!
Get rid of 90% of your code!
You do not need interrupts for this program.
You do not need to set tris either(compiler's very smart,does it for you!
First thing I'd do is to create a 'read keyboard' function. Start with reading the ports and sending data to a PC terminal program to confirm the keys are correct. Then add your 'chk_status' function, test, confirm that your logic is correct, again sending data to a PC terminal program.
You do NOT want to initialise porta pins high. You chose them to be INPUTS and have pullups/switches on them not OUTPUTs.
Same hold true for B4 and B5.
Same problem with C3.
In fact get rid of the entire 'initialise' function.
ther's more 'wrong' but I need to get a coffee....
hth
jay
