CCS C compiler did not come with dsPIC header files
eugenius
PostPosted: Wed Jun 19, 2013 6:21 pm     Reply with quote
Hello, I have been using CCS C compiler for a few years now, and recently I began to play around with dsPIC's. I obtained a dspic30f4011.
My CCS C compiler does include the dspic30f4011 and I was able to set it up using the pic wizard, but when I went to compile it could not find the header file. I looked in the devices folder and could not find the header files for any dsPICs. Is there a way I can download it somewhere?
-Gene
stinky
PostPosted: Wed Jun 19, 2013 8:12 pm     Reply with quote
According to CCS the PCD compiler supports that device:
http://www.ccsinfo.com/devices.php?page=devices
If you have the PCD compiler and it's missing the file I'm sure they will help you out.
PostPosted: Thu Jun 20, 2013 12:11 am     Reply with quote
30F4011.h is included with all V4 and V5 PCD versions. Seems like you don't have the 16-Bit PIC compiler installed.
