Knight_FlyCn
LCD 2*16 with 18f4620 |
Posted: Wed Jun 05, 2013 1:00 pm |
I finding code LCD 4bit for 18f4620. who can help me ? _________________ Thinh |
Posted: Wed Jun 05, 2013 1:33 pm |
One version (LCD.C) comes with the compiler. More flexible, and generally as/more reliable, is the 'flex lcd' driver in the code forum.
Learn to use search before asking questions. |
Knight_FlyCn
Posted: Thu Jun 06, 2013 12:26 pm |
This is my code
Code: | #include <RFD.h>
#include "string.h"
#include "stdio.h"
#include "def_18f4620.c"
#include "slave_1_tx_rx.h"
#include "LCD.C"
#bit CS = 0xF83.0
#bit RST = 0xF83.2
#bit INT_ = 0xF81.1
#bit WAKE = 0xF83.1
#bit CS_Direction = 0xF95.0
#bit RST_Direction = 0xF95.2
#bit INT_Direction = 0xF93.1
// Enter Code Here
#define LCD_ENABLE_PIN TRISD2 ////
#define LCD_RS_PIN TRISD0 ////
#define LCD_RW_PIN TRISD1 ////
#define LCD_DATA4 TRISD4 ////
#define LCD_DATA5 TRISD5 ////
#define LCD_DATA6 TRISD6 ////
#define LCD_DATA7 TRISD7 ////
INT TEMP;
INT giatri = 0;
INT DATA_SEND=2;
INT COMMAND;
SHORT SLEEP_MODE=true;
int i;
char value[12];
TRISC0 = 0;
CS_Direction = 0; // Set direction to be output
RST_Direction = 0; // Set direction to be output
INT_Direction = 1; // Set direction to be input
WAKE_Direction = 0; // Set direction to be output
Delay_ms(5);
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4); // Initialize SPI module
pin_reset(); // Activate reset from pin
software_reset(); // Activate software reset
RF_reset(); // RF reset
set_WAKE_from_pin(); // Set wake from pin
set_long_address(ADDRESS_long_1);
set_short_address(rfd_ADDRESS_short); // Set short address
set_PAN_ID(PAN_ID); // Set PAN_ID
init_ZIGBEE_nonbeacon(); // Initialize ZigBee module
nonbeacon_device();
set_TX_power(31); // Set max TX power
set_frame_format_filter(1); // 1 all frames, 3 data frame only
set_reception_mode(1); // 1 normal mode
enable_int();
pin_wake(); // Wake from pin
//enable interrupt ext
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
ext_int_edge(H_to_L);
// gioi thieu
lcd_putc(" Hello Hello");
Printf(" Bat Dau Lai RFID 1\r\n");
while (1)
for (i=0; i<12; i++) { //read in the 12 values
value[i]=getc();
printf("RFID %c %c %c %c %c %c %c %c %c %c \r\n", value[1] value[2] value[3] value[4] value[5] value[6] value[7] value[8] value[9] value[10]); //display 10 unique id digits
But don't anything happen. Where is my wrong ? _________________ Thinh |
Posted: Thu Jun 06, 2013 12:30 pm |
Because things have to be defined _before_ they are used. How is LCD, meant to know about your pin definitions?.... |
Posted: Thu Jun 06, 2013 1:10 pm |
Why did you define the lcd pins as TRIS register settings ?
The CCS example in the lcd.c file doesn't do this.
Why did you do it ?
Here is the CCS example from lcd.c, and it shows pin numbers:
//// Example of pin access:
//// #define LCD_ENABLE_PIN PIN_E0
//// #define LCD_RS_PIN PIN_E1
//// #define LCD_RW_PIN PIN_E2
//// #define LCD_DATA4 PIN_D4
//// #define LCD_DATA5 PIN_D5
//// #define LCD_DATA6 PIN_D6
//// #define LCD_DATA7 PIN_D7 |
Knight_FlyCn
Posted: Thu Jun 06, 2013 1:11 pm |
I repair it
#include "string.h"
#include "stdio.h"
#include "LCD.C"
#bit CS = 0xF83.0
#bit RST = 0xF83.2
#bit INT_ = 0xF81.1
#bit WAKE = 0xF83.1
// Enter Code Here
INT TEMP;
INT giatri = 0;
INT DATA_SEND=2;
INT COMMAND;
int i;
char value[12];
TRISC0 = 0;
Delay_ms(5);
nonbeacon_device();
enable_int();
// gioi thieu
lcd_init();
while (1)
value[i]=getc();
But dont' happend. who help me ? _________________ Thinh |
Knight_FlyCn
Posted: Thu Jun 06, 2013 1:13 pm |
PCM programmer wrote: | Quote: |
Why did you do it ?
Because I use file "def_18f4620.c" for myselfs .
Code: | // PIC 18F4620
// EDIT BY NGUYEN VAN THINH
#define T 0
#define F 1
#byte TOSU = 0xFFF
#byte TOSH = 0xFFE
#byte TOSL = 0xFFD
#byte STKPTR = 0xFFC
#byte PCLATU = 0xFFB
#byte PCLATH = 0xFFA
#byte PCL = 0xFF9
#byte TBLPTRU = 0xFF8
#byte TBLPTRH = 0xFF7
#byte TBLPTRL = 0xFF6
#byte TABLAT = 0xFF5
#byte PRODH = 0xFF4
#byte PRODL = 0xFF3
#byte INTCON = 0xFF2
#byte INTCON2 = 0xFF1
#byte INTCON3 = 0xFF0
#byte INDF0 = 0xFEF
#byte POSTINC0 = 0xFEE
#byte POSTDEC0 = 0xFED
#byte PREINCO = 0xFEC
#byte PLUSW0 = 0xFEB
#byte FSR0H = 0xFEA
#byte FSROL = 0xFE9
#byte WREG = 0xFE8
#byte INDF1 = 0xFE7
#byte POSTINC1 = 0xFE6
#byte POSTDEC1 = 0xFE5
#byte PREINC1 = 0xFE4
#byte PLUSW1 = 0xFE3
#byte FSR1H = 0xFE2
#byte FSR1L = 0xFE1
#byte BSR = 0xFE0
#byte INDF2 = 0xFDF
#byte POSTINC2 = 0xFDE
#byte POSTDEC2 = 0xFDD
#byte PREINC2 = 0xFDC
#byte PLUSW2 = 0xFDB
#byte FSR2H = 0xFDA
#byte FSR2L = 0xFD9
#byte STATUS = 0xFD8
#byte TMR0H = 0xFD7
#byte TMR0L = 0xFD6
#byte T0CON = 0xFD5
#byte OSCCON = 0xFD3
#byte HLVDCON = 0xFD2
#byte WDTCON = 0xFD1
#byte RCON = 0xFD0
#byte TMR1H = 0xFCF
#byte TMR1L = 0xFCE
#byte T1CON = 0xFCD
#byte TMR2 = 0xFCC
#byte PR2 = 0xFCB
#byte T2CON = 0xFCA
#byte SSPBUF = 0xFC9
#byte SSPADD = 0xFC8
#byte SSPSTAT = 0xFC7
#byte SSPCON1 = 0xFC6
#byte SSPCON2 = 0xFC5
#byte ADRESH = 0xFC4
#byte ADRESL = 0xFC3
#byte ADCON0 = 0xFC2
#byte ADCON1 = 0xFC1
#byte ADCON2 = 0xFC0
#byte CCPR1H = 0xFBF
#byte CCPR1L = 0xFBE
#byte CCP1CON = 0xFBD
#byte CCPR2H = 0xFBC
#byte CCPR2L = 0xFBB
#byte CCP2CON = 0xFBA
#byte BAUDCON = 0xFB8
#byte PWM1CON = 0xFB7
#byte ECCP1AS = 0xFB6
#byte CVRCON = 0xFB5
#byte CMCON = 0xFB4
#byte TMR3H = 0xFB3
#byte TMR3L = 0xFB2
#byte T3CON = 0xFB1
#byte SPBRGH = 0xFB0
#byte SPBRG = 0xFAF
#byte RCREG = 0xFAE
#byte TXREG = 0xFAD
#byte TXSTA = 0xFAC
#byte RCSTA = 0xFAB
#byte EEADRH = 0xFAA
#byte EEADRR = 0xFA9
#byte EEDATA = 0xFA8
#byte EECON2 = 0xFA7
#byte EECON1 = 0xFA6
#byte IPR2 = 0xFA2
#byte PIR2 = 0xFA1
#byte PIE2 = 0xFA0
#byte IPR1 = 0xF9F
#byte PIR1 = 0xF9E
#byte PIE1 = 0xF9D
#byte OSCTUNE = 0xF9B
#byte TRISE = 0xF96
#bit TRISE0 = 0xF96.0
#bit TRISE1 = 0xF96.1
#bit TRISE2 = 0xF96.2
#bit TRISE3 = 0xF96.3
#bit TRISE4 = 0xF96.4
#bit TRISE5 = 0xF96.5
#bit TRISE6 = 0xF96.6
#bit TRISE7 = 0xF96.7
#byte TRISD = 0xF95
#bit TRISD0 = 0xF95.0
#bit TRISD1 = 0xF95.1
#bit TRISD2 = 0xF95.2
#bit TRISD3 = 0xF95.3
#bit TRISD4 = 0xF95.4
#bit TRISD5 = 0xF95.5
#bit TRISD6 = 0xF95.6
#bit TRISD7 = 0xF95.7
#byte TRISC = 0xF964
#bit TRISC0 = 0xF94.0
#bit TRISC1 = 0xF94.1
#bit TRISC2 = 0xF94.2
#bit TRISC3 = 0xF94.3
#bit TRISC4 = 0xF94.4
#bit TRISC5 = 0xF94.5
#bit TRISC6 = 0xF94.6
#bit TRISC7 = 0xF94.7
#byte TRISB = 0xF93
#bit TRISB0 = 0xF93.0
#bit TRISB1 = 0xF93.1
#bit TRISB2 = 0xF93.2
#bit TRISB3 = 0xF93.3
#bit TRISB4 = 0xF93.4
#bit TRISB5 = 0xF93.5
#bit TRISB6 = 0xF93.6
#bit TRISB7 = 0xF93.7
#byte TRISA = 0xF92
#bit TRISA0 = 0xF92.0
#bit TRISA1 = 0xF92.1
#bit TRISA2 = 0xF92.2
#bit TRISA3 = 0xF92.3
#bit TRISA4 = 0xF92.4
#bit TRISA5 = 0xF92.5
#bit TRISA6 = 0xF92.6
#bit TRISA7 = 0xF92.7
#byte LATE = 0xF8D
#bit LATE0 = 0xF8D.0
#bit LATE1 = 0xF8D.1
#bit LATE2 = 0xF8D.2
#bit LATE3 = 0xF8D.3
#bit LATE4 = 0xF8D.4
#bit LATE5 = 0xF8D.5
#bit LATE6 = 0xF8D.6
#bit LATE7 = 0xF8D.7
#byte LATD = 0xF8C
#bit LATD0 = 0xF8C.0
#bit LATD1 = 0xF8C.1
#bit LATD2 = 0xF8C.2
#bit LATD3 = 0xF8C.3
#bit LATD4 = 0xF8C.4
#bit LATD5 = 0xF8C.5
#bit LATD6 = 0xF8C.6
#bit LATD7 = 0xF8C.7
#byte LATC = 0xF8B
#bit LATC0 = 0xF8B.0
#bit LATC1 = 0xF8B.1
#bit LATC2 = 0xF8B.2
#bit LATC3 = 0xF8B.3
#bit LATC4 = 0xF8B.4
#bit LATC5 = 0xF8B.5
#bit LATC6 = 0xF8B.6
#bit LATC7 = 0xF8B.7
#byte LATB = 0xF8A
#bit LATB0 = 0xF8A.0
#bit LATB1 = 0xF8A.1
#bit LATB2 = 0xF8A.2
#bit LATB3 = 0xF8A.3
#bit LATB4 = 0xF8A.4
#bit LATB5 = 0xF8A.5
#bit LATB6 = 0xF8A.6
#bit LATB7 = 0xF8A.7
#byte LATA = 0xF89
#bit LATA0 = 0xF89.0
#bit LATA1 = 0xF89.1
#bit LATA2 = 0xF89.2
#bit LATA3 = 0xF89.3
#bit LATA4 = 0xF89.4
#bit LATA5 = 0xF89.5
#bit LATA6 = 0xF89.6
#bit LATA7 = 0xF89.7
#byte PORTE = 0xF84
#bit RE0 = 0xF84.0
#bit RE1 = 0xF84.1
#bit RE2 = 0xF84.2
#bit RE3 = 0xF84.3
#bit RE4 = 0xF84.4
#bit RE5 = 0xF84.5
#bit RE6 = 0xF84.6
#bit RE7 = 0xF84.7
#byte PORTD = 0xF83
#bit RD0 = 0xF83.0
#bit RD1 = 0xF83.1
#bit RD2 = 0xF83.2
#bit RD3 = 0xF83.3
#bit RD4 = 0xF83.4
#bit RD5 = 0xF83.5
#bit RD6 = 0xF83.6
#bit RD7 = 0xF83.7
#byte PORTC = 0xF82
#bit RC0 = 0xF82.0
#bit RC1 = 0xF82.1
#bit RC2 = 0xF82.2
#bit RC3 = 0xF82.3
#bit RC4 = 0xF82.4
#bit RC5 = 0xF82.5
#bit RC6 = 0xF82.6
#bit RC7 = 0xF82.7
#byte PORTB = 0xF81
#bit RB0 = 0xF81.0
#bit RB1 = 0xF81.1
#bit RB2 = 0xF81.2
#bit RB3 = 0xF81.3
#bit RB4 = 0xF81.4
#bit RB5 = 0xF81.5
#bit RB6 = 0xF81.6
#bit RB7 = 0xF81.7
#byte PORTA = 0xF80
#bit RA0 = 0xF80.0
#bit RA1 = 0xF80.1
#bit RA2 = 0xF80.2
#bit RA3 = 0xF80.3
#bit RA4 = 0xF80.4
#bit RA5 = 0xF80.5
#bit RA6 = 0xF80.6
#bit RA7 = 0xF80.7
// --------SERIAL PORT BITS----------------------------------
#BIT TX9 = TXSTA.6
#BIT TXEN = TXSTA.5
#BIT SYNC = TXSTA.4
#BIT BRGH = TXSTA.2
#BIT SPEN = RCSTA.7
#BIT RX9 = RCSTA.6
#BIT SREN = RCSTA.5
#BIT CREN = RCSTA.4
#BIT FERR = RCSTA.2
#BIT OERR = RCSTA.1
#BIT TXIE = PIE1.4
#BIT RCIE = PIE1.5
#BIT RCIF = PIR1.5
//;----- INTCON Bits -----------------------------------------------------
#bit RBIF =INTCON.0
#bit INT0F =INTCON.1
#bit TMR0IF =INTCON.2
#bit RBIE =INTCON.3
#bit INT0E =INTCON.4
#bit TMR0IE =INTCON.5
#bit PEIE =INTCON.6
#bit GIE =INTCON.7
#bit INT0IF =INTCON.1
#bit T0IF =INTCON.2
#bit INT0IE =INTCON.4
#bit T0IE =INTCON.5
#bit GIEL =INTCON.6
#bit GIEH =INTCON.7 |
Posted: Thu Jun 06, 2013 1:18 pm |
I don't care what you want to do. If you use a driver written by someone
else, the driver will tell you how to use it. You must follow the
instructions in the driver to make it work correctly. If you invent your
own way, the driver will not work.
Fix the #define statements for the lcd pins the way that I showed in
my previous post.
Also fix the order of the #define statements and the #include for lcd.c
as shown in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=47663&start=1
If you do those two things, then you have a chance for the lcd to work. |
