Help For reading Port Data
prafulla.prolific
PostPosted: Thu Jun 06, 2013 1:06 am     Reply with quote
I am using PIC 16F873A controller 8 keys attached to controller. On PORT_A (6 keys) from Pin A0-A5, and ON Port B (2 keys) Pin B4, & B5. I am writing Port_A make with pullup make Port_A High and read PORT_A data if Port_A data changes means changes in key status they next process of debounce carried out.
I had write code as following as shown in example but shows error as
: expecting LVALUE such as variable name or * expression
unsigned int8 key2_data(void);
unsigned int8 data1(void);
unsigned int8 data2(void);
unsigned int8 key_data(void);
void chk_status(void)
   data1=input_B();
   data2=input_A();
   key2_data = ( data1 & 0x30);
   key2_data = key2_data <<2;
   key_data  = (( data2 & 0x3F)|( key2_data & 0xa0));
i had also change input_B as PORT_B,please guide how to read port data.
I m Working as PIC Programmer Fresher
PostPosted: Thu Jun 06, 2013 7:11 am     Reply with quote
Nothing wrong with the input. Problem is the data definitions....
You are defining key2_data, as a _function_ returning an int8, not as a variable.
Same applies to all the other variables....
With some further tidying (for instance, you have already and'ed the incoming port value with 0x30, before the rotation, so why and it again with 0xA0 - just wasted time.
Also as a comment, use local variables, and return the value from the function.
int8 chk_status(void)
   int8 temp;
   temp=(input_B()<<2) & 0xA0);
   temp=(input_A() & 0x3F) | temp;
   return temp;
Note the variable declaration, and how the function returns the result.
Do some basic reading on how to declare variables in C.
PostPosted: Thu Jun 06, 2013 7:24 am     Reply with quote
you are treating function templates as if they are VARS
read your basic C manual
this is wrong syntax you attempt to compile.
not a CCS problrm
ohh whoops - MR. T was setting this right as i was typing Slowly Very Happy Very Happy Very Happy
PostPosted: Thu Jun 06, 2013 8:34 am     Reply with quote
Stereo posting is very common. Usually I'm the one typing slower... Smile
prafulla.prolific
PostPosted: Fri Jun 07, 2013 11:56 pm     Reply with quote
Thanks Ttelmah, its my mistake i will try.
   int8 temp;
   return temp;
