CS5532 / 34 Driver Help !
mglsoft
PostPosted: Tue Jun 04, 2013 5:20 pm     Reply with quote
Someone has made a driver that works for the A/D converter CS5532 or CS5534?
If you also want to share that would be fabulous!
MGLSOFT
PostPosted: Wed Jun 05, 2013 10:41 am     Reply with quote
once you decide you need to operate in 24 bit space
you have bigger issues than just the driver code.
realizing clean , accurate, low noise results from even a 16 bit
converter is demanding enough, but the analog and power supply design
has to be damned good to get results that justify the cost of the parts.
HINT: Development is not gonna happen on a breadboard!
BTDT with TI parts and i kid you not in the least..... Very Happy Very Happy Very Happy
PostPosted: Wed Jun 05, 2013 11:46 am     Reply with quote
If you study the data sheet for this part, this is 'why' it is careful to tell you that you can use opto-couplers to drive it.
I's say it is very hard to design a board to carry this part, and directly drive it from a processor. I'd definitely be considering having an 'analog only' section to the board, probably fed with a separate analog supply, with opto-coupling back to the 'digital' section.
Circuit design for this is perhaps 50* harder than the 'driver' code.
mglsoft
PostPosted: Wed Jun 05, 2013 11:48 am     Reply with quote
Thanks for answering!
I understand in the field that I'm getting and complexity.
For now follow the manufacturer's recommendations (Cirrus) with respect to hardware design.
I understand that is subject to many considerations.
A question (knowing that English is not my native language):
What does the acronym BTDT??
MGLSOFT
PostPosted: Wed Jun 05, 2013 12:06 pm     Reply with quote
Been There, Done That - means they have experience in that area, sometimes not a good experience...
