Cogitum
Joined: 22 Mar 2012 Posts: 70 Location: France (Paris)
MS5607 Altimeter - Need help porting Atmel code to CCS |
Posted: Mon Jun 03, 2013 10:22 am |
Hi
I'm tying to compile this program (original for Atmel Atmega644p) without success. AN 520 from MEASUREMENT.
I would like use the pic 18F25K80 in I2C mode.
Compiler version 4.132
Thanks in advance for your help.
#include <fichierDef.h>
/// PIC 18F25K80 at 4MHZ
//! @brief This C code is for starter reference only. It is written for the
//! MEAS Switzerland MS56xx pressure sensor modules and Atmel Atmega644p
//! microcontroller.
//_____ M A C R O S
#define ADDR_W 0xEE // Module address write mode
#define ADDR_R 0xEF // Module address read mode
#define CMD_RESET 0x1E // ADC reset command
#define CMD_ADC_READ 0x00 // ADC read command
#define CMD_ADC_CONV 0x40 // ADC conversion command
#define CMD_ADC_D1 0x00 // ADC D1 conversion
#define CMD_ADC_D2 0x10 // ADC D2 conversion
#define CMD_ADC_256 0x00 // ADC OSR=256
#define CMD_ADC_512 0x02 // ADC OSR=512
#define CMD_ADC_1024 0x04 // ADC OSR=1024
#define CMD_ADC_2048 0x06 // ADC OSR=2048
#define CMD_ADC_4096 0x08 // ADC OSR=4096
#define CMD_PROM_RD 0xA0 // Prom read command
//_____ I N C L U D E S
#include <stdio.h>
#include <math.h>
//_____ D E F I N I T I O N S
unsigned char i2c_start(unsigned char address);
void i2c_stop(void);
unsigned char i2c_write( unsigned char data );
unsigned char i2c_readAck(void);
unsigned char i2c_readNak(void);
//void cmd_reset(void);
unsigned long cmd_adc(char cmd);
unsigned int cmd_prom(char coef_num);
unsigned char crc4(unsigned int n_prom[]);
//! @brief send I2C start condition and the address byte
//! @return 0
unsigned char twst;
TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN); // send START condition
while(!(TWCR & (1<<TWINT))); // wait until transmission completed
twst = TW_STATUS & 0xF8;// check value of TWI Status Register. Mask prescaler bits.
if ( (twst != TW_START) && (twst != TW_REP_START)) return 1;
TWDR = address; // send device address
TWCR = (1<<TWINT) | (1<<TWEN);
// wait until transmission completed and ACK/NACK has been received
if ( (twst != TW_MT_SLA_ACK) && (twst != TW_MR_SLA_ACK) ) return 1;
return 0;
//! @brief send I2C stop condition
//! @return none
void i2c_stop(void)
/* send stop condition */
TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWSTO);
// wait until stop condition is executed and bus released
while(TWCR & (1<<TWSTO)); //THIS MAKES PROBLEM FOR IS2402
//! @return 0
unsigned char i2c_write(unsigned char data)
unsigned char twst;
TWDR = data; // send data to the previously addressed device
twst = TW_STATUS & 0xF8; // check value of TWI Status Register. Mask prescaler bits
if( twst != TW_MT_DATA_ACK) return 1;
return 0;
//! @brief read I2C byte with acknowledgment
//! @return read byte
TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWEA);
return TWDR;
//! @brief read I2C byte without acknowledgment
return TWDR;
//! @brief send command using I2C hardware interface
//! @return none
void i2c_send(char cmd)
unsigned char ret;
ret = i2c_start(ADDR_W); // set device address and write mode
if ( ret )
{//failed to issue start condition, possibly no device found */
i2c_stop();
{// issuing start condition ok, device accessible
ret=i2c_write(cmd);
i2c_stop();
//! @brief send reset sequence
//! @return none
i2c_send(CMD_RESET); // send reset sequence
_delay_ms(3); // wait for the reset sequence timing
//! @brief preform adc conversion
//! @return 24bit result
unsigned int ret;
unsigned long temp=0;
i2c_send(CMD_ADC_CONV+cmd); // send conversion command
switch (cmd & 0x0f) // wait necessary conversion time
case CMD_ADC_256 : delay_us(900); break;
case CMD_ADC_512 : delay_ms(3); break;
case CMD_ADC_1024: delay_ms(4); break;
case CMD_ADC_2048: delay_ms(6); break;
case CMD_ADC_4096: delay_ms(10); break;
i2c_send(int8 CMD_ADC_READ);
ret = i2c_start(ADDR_R); // set device address and read mode
if ( ret )
i2c_stop();
{//issuing start condition ok, device accessible
ret = i2c_readAck(); // read MSB and acknowledge
temp=65536*ret;
ret = i2c_readAck(); // read byte and acknowledge
temp=temp+256*ret;
ret = i2c_readNak(); // read LSB and not acknowledge
temp=temp+ret;
i2c_stop(); // send stop condition
return temp;
//! @brief Read calibration coefficients
//! @return coefficient
unsigned int ret;
unsigned int rC=0;
i2c_send(CMD_PROM_RD+coef_num*2); // send PROM READ command
if ( ret )
i2c_stop();
rC=256*ret;
rC=rC+ret;
i2c_stop();
return rC;
//! @brief calculate the CRC code
//! @return crc code
int cnt; // simple counter
unsigned int n_rem; // crc reminder
unsigned int crc_read; // original value of the crc
unsigned char n_bit;
n_rem = 0x00;
crc_read=n_prom[7]; //save read CRC
n_prom[7]=(0xFF00 & (n_prom[7])); //CRC byte is replaced by 0
for (cnt = 0; cnt < 16; cnt++) // operation is performed on bytes
{// choose LSB or MSB
if (cnt%2==1) n_rem ^= (unsigned short) ((n_prom[cnt>>1]) & 0x00FF);
else n_rem ^= (unsigned short) (n_prom[cnt>>1]>>8);
for (n_bit = 8; n_bit > 0; n_bit--)
if (n_rem & (0x8000))
n_rem = (n_rem << 1) ^ 0x3000;
n_rem = (n_rem << 1);
n_rem= (0x000F & (n_rem >> 12)); // final 4-bit reminder is CRC code
n_prom[7]=crc_read; // restore the crc_read to its original place
return (n_rem ^ 0x0);
//! @brief main program
//! @return 0
void main (void)
unsigned long D1; // ADC value of the pressure conversion
unsigned long D2; // ADC value of the temperature conversion
unsigned int C[8]; // calibration coefficients
double P; // compensated pressure value
double T; // compensated temperature value
double dT; // difference between actual and measured temperature
double OFF; // offset at actual temperature
double SENS; // sensitivity at actual temperature
int i;
unsigned char n_crc; // crc value of the prom
// initialize the I2C hardware module
for (i=0;i<8;i++){ C[i]=cmd_prom(i);} // read coefficients
n_crc=crc4(C); // calculate the CRC
for(;;) // loop without stopping
D2=cmd_adc(CMD_ADC_D2+CMD_ADC_4096); // read D2
D1=cmd_adc(CMD_ADC_D1+CMD_ADC_4096); // read D1
// calcualte 1st order pressure and temperature (MS5607 1st order algorithm)
dT=D2-C[5]*pow(2,8);
OFF=C[2]*pow(2,17)+dT*C[4]/pow(2,6);
SENS=C[1]*pow(2,16)+dT*C[3]/pow(2,7);
T=(2000+(dT*C[6])/pow(2,23))/100;
P=(((D1*SENS)/pow(2,21)-OFF)/pow(2,15))/100;
// place to use P, T, put them on LCD, send them trough RS232 interface...
return 0;
#include <18F25K80.h>
#device adc=12
#FUSES WDT //No Watch Dog Timer
//#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES VREGSLEEP_SW //Ultra low-power regulator is enabled
#FUSES INTRC_HP //LF-INTOSC in Low-Power mode during Sleep
#FUSES HSH //High speed Osc, medium power 4MHz-16MHz
//#FUSES NOPLLEN //4X HW PLL disabled, 4X PLL enabled in software
//#FUSES WDT_NOSLEEP //Watch Dog Timer, disabled during SLEEP
//#use delay(crystal=4000000)
#use delay(crystal=4M)
//#use delay(clock=4M, crystal)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
Posted: Tue Jun 04, 2013 2:31 am |
Classic problem. Data sizes.
In CCS, an 'int', is the default size the chip works with, so an int8. In most other C's, it is an int16.
If you look at 'cmd_prom' for example, it is returning an int16 value, but is declared to return an 'int'. Hence won't work in CCS. Same applies to 'long', which is an int32, but an int16 in CCS.
You could either use #type to redefine the sizes, or just change all the references.
#type SIGNED
#type INT=16, LONG=32
Might get close.
