structure assignment syntax
asmboy
PostPosted: Fri May 31, 2013 11:20 am     Reply with quote
i am struggling with a simple - but frustrating problem.
am sure is ME not the compiler.
16 sets of 8 elements 'wellx'
the low 4 values of each of 16 payloads are set as 'virtual' constants
the upper 4 are meant to accept data from user in runtime
no problem with the runtime, assignment and readback -
but struggling to get the syntax right to declare and load
welldat[][] at startup/reset
typedef struct {
   int8  rexcite;
   byte  rgains;
} wellx;
//  [1of16 kinds][8 different 'payloads']
wellx welldat[16][8];
// there are 16 groups of 8 wellx's
// typical  data for one of the payloads:
//  {100,0xA7}   typical of first 4 of 8  [0-3]
//  {0,0xFF}  for unused 'soft' user upload values [4-7]
how to assign and get the load order right for all of welldat[][] ??
PostPosted: Fri May 31, 2013 3:28 pm     Reply with quote
This shows how to initialize a 2-dimensional array where each array element is a structure:
#include <18F4520.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
typedef struct {
int8  a;
int8  b;
}ab_t;
#define NUM_ROWS  4
#define NUM_COLUMNS  3
ab_t array[NUM_ROWS][NUM_COLUMNS] = {
{{1,2}, {3,4}, {5,6}},
{{7,8}, {9,10}, {11,12}},
{{13,14}, {15,16}, {17,18}},
{{19,20}, {21,22}, {23,24}}
int8 row, col;
for(row = 0; row < NUM_ROWS; row++)
    for(col=0; col < NUM_COLUMNS; col++)
        printf("%u,%u  ", array[row][col].a, array[row][col].b);
    printf("\r");
Here is the output in MPLAB simulator:
1,2 3,4 5,6
7,8 9,10 11,12
13,14 15,16 17,18
19,20 21,22 23,24
asmboy
PostPosted: Fri May 31, 2013 4:16 pm     Reply with quote
THANK YOU very much
i was testing on a 2x2 struct array also - and looking at the
.LST file with confusion galore-
but
what i was missing was the nested {} DUH !!
SO much appreciated... Very Happy Very Happy Very Happy
