18F4620 get data RX port
Knight_FlyCn
PostPosted: Sun May 26, 2013 12:05 pm     Reply with quote
I read data from RX (RFID tag - Reader: RDM6300) by code:
volatile char StartFlag = 0;
volatile char StopFlag = 0;
char array[12];
int i;
#INT_RDA
void interrupt()
   RCIF = 0;
    if (RCREG == 0X02)                    /*  check for start byte               */
      StartFlag = 1;
    if (StartFlag == 1 && RCREG != 0X03)
       array[i] = RCREG;/*  store received data into an array  */
       i++;
    if (RCREG == 0X03)                    /*  10 byte data is received           */
       array[i] = '\0';
      StopFlag = 1;
        i = 0;
But don't anything in array[i] . I don't known and who can help me ?
And when I connect PIC with PC. I used code:
c=getc();
Why I used it for RFID don't working
Thinh
PostPosted: Sun May 26, 2013 12:49 pm     Reply with quote
One thing I notice is Start_Flag, once set, always stays 1
You should fetch RCREG into a temp variable for test
You should test for the end byte second, not last. then
you can remove the end byte test from your data
input routine.
Without more to go on...
Mike Walne
Sorry, can't help.
Your code is neither complete nor compilable, so it's not possible to copy and paste to test.
Could be allsorts of issues, you don't provide enough information.
I suggest you read and follow the forum guidelines.
Mike
PostPosted: Sun May 26, 2013 1:23 pm     Reply with quote
Comments:
RCIF=0;
Does nothing. RCIF _cannot be cleared till the character is read_.
The compiler automatically tries to clear RCIF for you when the routine exits, but this too won't work, because of the next problem.
Big problem is that you must _always_ physically read the byte received. Now a test for equality, won't necessarily read the byte. So when 2 is received the interrupt can't be cleared, and the code will loop for ever.
Use:
#INT_RDA
void interrupt()
  int8 rxchar;
  rxchar=getc();          //now you have read the char
  if (rxchar == 0X02)   // check for start byte
     StartFlag = TRUE;
     i=0; //make sure we start at the beginning
     if (StartFlag)
         if (rxchar == 0X03)
            array[i] = '\0';
            StopFlag = TRUE;
            StartFlag = FALSE;
            i = 0;
            array[i++] = rxchar;    //  store received data into an array
Make the array slightly larger, just in case something unexpected arrives.
