I have a Problem!! led dot matrix 8x8 control by switch
shamanjum
PostPosted: Tue May 21, 2013 9:29 am     Reply with quote
I'm Thai. English I'm not sure. I have a problem, Led dot matrix 8x8. I need use switch control LED. Click switch 1 for left, Switch 2 for right, switch 3 for up, switch 4 for down. By LED col use port b, LED row use port d, Switch use port a0,a1,a2,a3 . If wrongs I'm not good at English. Thanks.
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#define    left_sw      input(PIN_A0)
#define    right_sw     input(PIN_A1)
#define    up_sw        input(PIN_A2)
#define    down_sw      input(PIN_A3)
void main(void){
int i = 0;
int disp_buff[];
set_tris_b(0x00);
set_tris_d(0x00);
while(TRUE){
if(!left_sw){
    for(i=0;i<8;i++){
        disp_buff[i] <<= 1;
        output_b(disp_buff[i]) ;
   output_d(~(1 << i));
   delay_ms(50);
   i++;
if(!right_sw){
    for(i=0;i<8;i++){
        disp_buff[i] >>= 1;
   delay_ms(50);
   i++;
if(!up_sw){
    for(i=0;i<8;i++){
        disp_buff[i] = disp_buff[(i+1)&7] ;
   output_d(~(1 << i));        /
   delay_ms(50);
   i++;
if(!down_sw){
    for(i=0;i<8;i++){
        disp_buff[i] = disp_buff[(i-1)&7] ;
   delay_ms(50);
   i++;
PostPosted: Tue May 21, 2013 10:25 am     Reply with quote
void main(void){
int i = 0;
int disp_buff[];
In your code above, disp_buff is not an array. It's just a pointer. You
need to put the size of the array inside the brackets. Then the compiler
will allocate ram to the array, and you can save data in the array.
For example:
int disp_buff[8];
The switch circuits should look like this for pins A0, A1, A2, A3:
           +5v
            > 4.7K
            <         ___  Switch
To          |        _|_|_
PIC -----------------o   o------
pin                            |
                              --- GND
The pull-up resistor can be 10K or some other reasonable value.
shamanjum
PostPosted: Tue May 21, 2013 11:39 am     Reply with quote
Thank you very much.
shamanjum
PostPosted: Wed May 22, 2013 8:22 am     Reply with quote
Prrblem!! output ? I don't understand output.
ezflyr
PostPosted: Wed May 22, 2013 9:10 am     Reply with quote
Can you be more specific? Do you mean you don't understand the 'output_x' statement? Have you looked at the CCS manual? Did you write the code shown in your original post in this thread?
John
shamanjum
PostPosted: Wed May 22, 2013 9:19 am     Reply with quote
Yeah , I need datasheet. I have 5 hour for finish.
shamanjum
PostPosted: Wed May 22, 2013 9:37 am     Reply with quote
Hi John
I can't coding , Help me please. T_T
PostPosted: Wed May 22, 2013 12:48 pm     Reply with quote
Post a schematic of your circuit on a free image hosting service such
as http://www.imageshack.us and then post a link to the image here.
shamanjum
PostPosted: Wed May 22, 2013 11:31 pm     Reply with quote
To  RB 0- 7 -------------------- R x 8 --------------------|
        o +
Pin                                                           LED 8x8 matrix
        o -
Pic  RD 0 - 7 ---------------------------------------------- |
  |-- RA0 - 3 -----------------------------------Switch -------- R ------- +5v
Sorry I don't have Proteus.
PostPosted: Wed May 22, 2013 11:57 pm     Reply with quote
Post the manufacturer and part number of your LED array.
If you have a link to the data sheet for it, post it.
shamanjum
PostPosted: Wed May 22, 2013 11:59 pm     Reply with quote
Sorry. Led teacher's makes. Not number. T_T
ezflyr
PostPosted: Thu May 23, 2013 6:49 am     Reply with quote
Please post your teachers contact info, and we will contact them directly!
John
