PIC MODBUS
Goto page Previous  1, 2
dyeatman
PostPosted: Tue May 21, 2013 8:50 am     Reply with quote
Are you modifying the modbus.c file?
The word at the end of the USE RS232 lines should be ERRORS not ERROR.
Google and Forum Search are some of your best tools!!!!
RF_Developer
PostPosted: Tue May 21, 2013 9:01 am     Reply with quote
It's "errors" in my (v 4.132) modbus.c.
So, what CCS version are you using Magnus?
magnus
PostPosted: Tue May 21, 2013 12:45 pm     Reply with quote
I'm using 4.078 version.
But if I change word "ERROR" to "ERRORS" it works.
thanks for the tips, they really help me Very Happy
dyeatman
PostPosted: Tue May 21, 2013 1:09 pm     Reply with quote
If you had to change the word you are not using the original MODBUS.c file
I would be careful of other possible changes.
magnus
PostPosted: Wed May 22, 2013 7:45 am     Reply with quote
Do You recommend some Modbus master simulator?
yerpa
PostPosted: Wed May 22, 2013 2:35 pm     Reply with quote
I've had good luck with MDBUS by Calta Computer Systems.
I use B&B Model 485USB9F-2W converter that plugs into Windows USB port and provides two-wire RS-485 connections.
magnus
PostPosted: Tue May 28, 2013 9:46 am     Reply with quote
Hello again.
Now I'm testing with a internal software and It presents the message: Check Sum error.
What error is it?
PostPosted: Tue May 28, 2013 11:18 pm     Reply with quote
Checksum is used in MODBUS ASCII protocol, RTU has CRC. Maybe you are using wrong MODBUS mode.
Generally, you can review any detail in the MODBUS over serial line specification, see modbus.org.
magnus
PostPosted: Wed May 29, 2013 5:16 am     Reply with quote
Thank You! Very Happy
Page 2 of 2
