Strings on RS232
Goto page 1, 2  Next
aaronik19
Strings on RS232
PostPosted: Tue Apr 30, 2013 4:17 pm     Reply with quote
Dear All,
I have an issue when coming to send and process RS232 strings and integers. Please refer to the program below:
#include "C:\Users\anthea\Documents\PICC\pic18f4520_serial.h"
#include <string.h>
#include <stdlib.h>
#include <input.c>
#define LCD_ENABLE_PIN PIN_A1
#define LCD_RS_PIN PIN_A3
#define LCD_RW_PIN PIN_A2
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <LCD.C>
#define delay4led 3
int count, count2 = 0;
char text1[30]
#int_TIMER1
void  TIMER1_isr(void)
count++;
   if (count == 50)
      gets(text1);
      count = 0;
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_vref(FALSE);
   printf("\f");
   lcd_gotoxy(1,2);
        printf("welcom1e");
      output_high(Pin_B1);
      printf(text1);
I would like to send a string, let say "Country" or Integer "2000" and store it in an eeprom. for my first test, I tried to send a string and print it back on the terminal, but nothing is happening. Can someone tell me where is the problem. I tried to solve the problem alone but I found no more ideas. Your help is highly appreciated.
To tell you the whole story, at first I tried to display the whole integer on LCD and the LCD started to display character by character. I am assuming that this is because I used LCD_putc.
Mike Walne
PostPosted: Tue Apr 30, 2013 5:26 pm     Reply with quote
Seriously reduce the size of your code to test one thing only.
You ask for help with RS232, but your code is littered with LCD, SPI, etc.
I'm confused about what you are trying to do.
Post code with no more than 10 lines.
CCS provides examples to do the jobs you're asking for.
Mike
PostPosted: Tue Apr 30, 2013 6:14 pm     Reply with quote
can you imagine a case where
TIMER1_isr() will hang indefinitely ??
i can !!
Very Happy Very Happy Very Happy Very Happy
Mike Walne
PostPosted: Wed May 01, 2013 1:40 am     Reply with quote
When I said post code I meant the shortest possible complete and compilable we can copy and paste to test.
Mike
aaronik19
PostPosted: Wed May 01, 2013 2:00 am     Reply with quote
I tried but no success. Can someone tell me where is the problem?
PostPosted: Wed May 01, 2013 2:43 am     Reply with quote
I'll list a few problems:
1) Using gets in an interrupt. This is asmboy's comment, and is exactly right.
2) setup_spi. Wrong command. The command to disable the port is 'FALSE'. You are enabling the port.
3) You don't show your #USE RS232 line, but unless this contains ERRORS, the UART will hang if data arrives between the occasions when count==50;
4) Once something has been received, it'll print continuously.
Look at the CCS examples. They show a variety of ways of doing this.
How often are you intending to change the EEPROM?. Remember it's write life limitations.
Mike Walne
PostPosted: Wed May 01, 2013 2:59 am     Reply with quote
Simple answer. We can't tell easily from your posted code.
I, for one, don't intend to decipher it.
The CCS example EX_STR.C passes strings both ways between PIC & PC.
It's not a good example, but you should be able to pick out the comms part.
Mike
aaronik19
PostPosted: Wed May 01, 2013 3:18 am     Reply with quote
I took your advice and went back to basics. this is my code so far:
#include <string.h>
#include <stdlib.h>
#include <input.c>
#define  STRING_SIZE    51
int count = 0;
char input_str[STRING_SIZE];
#int_TIMER1
   setup_wdt(WDT_OFF);
   printf("\fwelcome\n");
   printf("\n\r Please enter some text: ");
   get_string(input_str, STRING_SIZE);
   printf("\n\n You entered: %S", input_str);
   delay_ms(2000);
   output_toggle(PIN_B2);
but the screen just execute "Welcome" and "Please enter some text:" and that's it. I also inserted a toggle Led to check if the code is being executed but still no suceess.
aaronik19
PostPosted: Wed May 01, 2013 3:19 am     Reply with quote
by the way i referred to ex_str.c example to make this program. As a terminal I am using the hyperterminal.
PostPosted: Wed May 01, 2013 3:38 am     Reply with quote
Comment:
A string is always _one character longer_ than it's size.
You have 51 characters allocated to the array, so can store a string that is a maximum of 50 characters long.
You need to limit the input size to 'STRING_SIZE-1'.
Almost certainly it is working, but is not seeing the 'end of line'. input_str, 'out of the box', looks for code 13 as the end of line marker. Using standard settings in Hyperterminal, it sends just line feed (code 10) when you hit the 'enter' key.
In Hyperterminal.
File
Properties.
ASCII setup
Top tickbox 'send line ends with line feeds'.
OK
OK
OK
aaronik19
PostPosted: Wed May 01, 2013 4:19 am     Reply with quote
thanks Ttelmah. It is working. I also re-open teh hyperterminal because for some reasons it stops responding. I am using Windows 7.
I also succeed to print the whole string on LCD Display as well. This is my final code which is 100% working just in case that another person has the same problem.
#include <string.h>
#include <stdlib.h>
#include <input.c>
#include <LCD.C>
int count = 0;
#int_TIMER1
   setup_wdt(WDT_OFF);
   output_B(0x00);
   output_toggle(PIN_B1);
   output_toggle(PIN_B0);
   printf(lcd_putc, "%S", input_str);
   delay_ms(2000);
aaronik19
PostPosted: Thu May 02, 2013 12:57 pm     Reply with quote
dear all, continued to work on this project. Now I would like to make an interrupt to avoid continuous polling when the slave needs to communicate with my Master PIC.
Am I right that the ISR for RS232 is the RDA? This one can be used also for other protocols such as RS485?
Can I have more that one RDA ISRs such as?
#int_rda
void rda_isr()
#int_rda_2
void rda_2_isr()
I am assuming that I can distiguish between one RDA to another by include the Stream tag when stating the RS232 definition.
Really thanks for your help and support
alan
PostPosted: Thu May 02, 2013 1:36 pm     Reply with quote
The int_rda will only work with hardware serial ports. So yes if your PIC has 2 hardware ports you will have 2 interrupts otherwise just one.
Regards
aaronik19
PostPosted: Thu May 02, 2013 1:45 pm     Reply with quote
thanks. yes, infact i was going to mention, i i have software uart, what interrupt i can use?
PostPosted: Thu May 02, 2013 2:29 pm     Reply with quote
Unless already used, you could use INT_EXT (B0) for the software interrupt. There is code here(either Ttelmah or PCM programmer) donated by one of them..to show how to do it.
If possible, use it for the slowest speed serial port.
Other options are using external UART<>I2C, UART<>SPI, 18F46k22,etc.
hth
jay
Goto page 1, 2  Next
Page 1 of 2
