gmtandi
CVD touch - ANx Read, 16F1527 |
Posted: Thu May 02, 2013 10:47 am |
I'm trying to build a capacitive touch switch, but found a few issues when reading ADC...
When i set AN0 as sensor and AN1 as reference, it works like a charm, but when i set AN1 as sensor and AN0 as reference, the values get wrong...
AN0 = PIN_A0
AN1 = PIN_A1
My compiler version: 4.130
Clock: internal, 16mhz
Datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/41458C.pdf
Code: | #include <16F1527.h>
#device adc=16
#FUSES WDT_SW //No Watch Dog Timer, enabled in Software
#use delay(clock=16000000)
#define LED1 PIN_E1
#define LED2 PIN_E0
#define LED3 PIN_G0
#define TOUCH_CHANNELS 5
#define TOUCH_TIMEOUT 25
int1 status[TOUCH_CHANNELS];
int8 timeout[TOUCH_CHANNELS];
int16 counter, value;
#INT_TIMER2
void int_timer2_isr(void)
for (int i = 0; i < TOUCH_CHANNELS; i++)
if (status[i] == 1)
timeout[i]++;
if (timeout[i] >= TOUCH_TIMEOUT)
status[i] = 0;
setup_timer_2(T2_DIV_BY_64,511,4);
counter = 0;
while(true)
counter++;
//delay_ms(1); // when printf();
output_high(PIN_A0);
set_adc_channel(sAN0); // (missing delay)
output_low(PIN_A1);
output_float(PIN_A1);
set_adc_channel(sAN1); // (missing delay)
value = read_adc();
if (value> 256)
status[1] = 1;
timeout[1] = 0;
if (status[0] == 1) { output_high(LED1); } else { output_low(LED1); }
if (status[1] == 1) { output_high(LED2); } else { output_low(LED2); }
if (status[2] == 1) { output_high(LED3); } else { output_low(LED3); }
if (counter == 200) {
//printf("%lu\n", leitura); //
counter = 0;
the "value" when A0 is the sensor is almost 0 when no touch, and when A1 is the sensor, it's about 65472
The datasheet doesn't says nothing special for AN0 that is different than AN1, i think that my pads are fine, with the mTouch Demo it works fine, it must to be something with my code on CCS
Thanks, |
Posted: Thu May 02, 2013 11:46 am |
Your comments say "missing delay". The 16F1527 data sheet says
there should be a 5us delay after changing the A/D channel, before
you read the ADC. Why did you leave off the delay ? |
gmtandi
Posted: Thu May 02, 2013 1:08 pm |
cause the delay was doing nothing when i was using AN0 as sensor and AN1 as reference, its working only with AN0 sensor, any other ADC is geting wrong results, i had already added a few delays and no different result got :\
that's why i added that comment, i had already tried with delays, i had changed the order a few events occurs and also didn't worked..
thanks |
