		| Author | Message |
		| filjoa
				| program crash |
				|  Posted: Wed May 01, 2013 12:12 pm |   |
				| Hi
 I try read from GPS module and write on windows terminal with PIC18F458 @ 20Mhz but program crash after read +-9 strings.
  	  | Code: |  	  | #include <18F458.h>
 #fuses HS,NOWDT,NOPROTECT,NOLVP,BROWNOUT,STVREN
 #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, stream=gpsport)
 #use rs232(baud=9600,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8, stream=outport)
 #include<string.h>
 #include<stdlib.h>
 int1 data_available=FALSE;
 char c;
 void rda_isr();
 #int_rda
 void rda_isr(void)
 c = getc(gpsport);
 data_available=TRUE;
 fputc(c,outport);
 enable_interrupts(INT_RDA);
 Any idea where stay the problem?
 best regards
		| ezflyr
				|  Posted: Wed May 01, 2013 12:15 pm |   |
				| Hi,
 Modify your #use rs232 line as shown below.
  	  | Code: |  	  | #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, stream=gpsport, Errors)
 BTW, your program is probably not 'crashing' in the traditional sense. Rather,
 the UART is becoming over-run, and is locking up, preventing other
 characters from being received. The addition of 'Errors' to the #use rs232 line
 will allow the UART to recover in the event of an over-run.
 It's not a good idea to be putting something like your putc inside the serial
 ISR. You should be reading characters into a buffer, and then printing them
 out in your Main() routine. Looke at the example program ex_sisr.c to see
 how this is done!
 John
		| filjoa
				|  Posted: Wed May 01, 2013 4:56 pm |   |
				| Hi
 thanks ezflyr
 Problem solved, with "ERRORS" add, it make UART reset...
 I know this is not correct, but is the 1st test, to start the program.
 best regards
 | You cannot post new topics in this forum You cannot reply to topics in this forum
