thierry91
Compiler error SCR=7660 [statement error ???] |
Posted: Tue Mar 05, 2013 1:42 pm |
*** Error 44 "mor.c" Line 1866(1,1): Internal Error - Contact CCS LABEL SCR=7660
on Compiler 4.134 PCH,
Error IS HERE :
#define COM_T1_SET_MAX_SPEED 0x54 // 'T'
#define COM_T2_SET_MAX_SPEED 0x55 // 'U'
switch (code)
case ...:
case COM_T1_SET_MAX_SPEED:
if (cond) return;
case COM_T2_SET_MAX_SPEED:
if (cond) return;
case ...:
default:
break
it was as I've add a case status in a switch statement....
Is there limits in the number of statement that can handle the switch statement in the compiler ?
or an error into the parser that cannot handle so long labels ?
--> tried other lengths same error
or an error into the parser that cannot handle too similar labels ?
---> tried other chars : same error
or an error into the parser that cannot handle these values ?
----> Quote: | tried 0x75 in replacement of 0x55 works, but NOT ACCEPTABLE |
So, were can I find a list of all errors (SCR/number), if it exists ?
Thierry |
Mike Walne
Posted: Tue Mar 05, 2013 2:59 pm |
Can you duplicate the error in a SMALL complete compilable program we can all test?
Mike |
Posted: Tue Mar 05, 2013 3:38 pm |
The usual reason for this type of behaviour is a syntax error possibly hundreds of lines earlier, that the compiler does not immediately flag, but then causes an inexplicable error later.
Other thing is something line having 'SET_MAX_SPEED' already defined earlier, which then gets expanded in the second definition....
thierry91
Posted: Wed Mar 06, 2013 6:22 am |
And no, there is no syntax error, since I just add only this part of code in a working project....,
case(s) are not duplicate,
#define(s) have no expand included
No, I cannot reproduce the error in a smaller code, but as I tried many and many ways to solve this problem,
I've found the solution, to bypass this compiler error.....
But why this error ?
case COM_SET_MAX_SPEED_1:
case COM_SET_MAX_SPEED_2:
case COM_SET_MAX_SPEED_FL:
case COM_SET_MIN_POS_FL:
to (solution !!!!!! )
case COM_SET_MAX_SPEED_1: ----------------
--------- MOVE the case statement,
************ I wish to have them in the same screen as reading the code, but it does not compile.......
now this code compile in my project, maybe an error in the way the compiler handle the labels....
Thierry |
Posted: Wed Mar 06, 2013 10:01 am |
Remember an expanded include, could include something in one of the compiler's own files.
Try the experiment of not adding the case, but instead adding a variable, and setting it equal to the defines. Then using a debugger or output of some sort, see what values it takes.
jchristf
Posted: Fri Apr 26, 2013 12:18 pm |
Try using #opt to reduce optimization |
