can bus
barikjk
can bus
PostPosted: Tue Apr 23, 2013 4:06 am     Reply with quote
Hello friends
I am using pic18F452 with MCP2515 & MCP2551 . CCS compiler have drivers - > can-mcp2510.c & can-mcp251x.c. which one will be suitable for my project?
thanks all
PostPosted: Tue Apr 23, 2013 1:45 pm     Reply with quote
Those two files are the same except for a few differences, as explained below:
In vs. 4.120, some lines were added or changed in can-mcp2510.c.
CCS didn't change can-mcp251x.c. They haven't made any other
changes since then.
The following lines were added or changed in can_set_mode():
   struct struct_CANSTAT new_CANSTAT;
      memset(&new_CANSTAT,mcp2510_read(CANSTAT),1);
   } while (new_CANSTAT.opmode != mode);
The following lines were added to can_init():
   output_low(EXT_CAN_SI);
   output_low(EXT_CAN_SCK);
   output_float(EXT_CAN_SO);
So assuming you have vs. 4.141 or a version near to that, I would say
you should use can-mcp2510.c, since it has the latest revisions from CCS.
