help with creating a menu for a digital clock with ds1302
claudia.crespo
PostPosted: Fri Apr 19, 2013 1:47 pm     Reply with quote
I'm trying to do a digital clock within a menu of different options
with a pic 18f4550 and a ds1302.
But i get an error at the beginning of all the functions i create Rolling Eyes
"a numeric expression must appear here"
Crying or Very sad
My comments are in spanish but i think is easy to understand.
I'll appreciate the help.
#include <18f4550.h>  //archivo de cabecera
#fuses hspll,mclr,nowdt,noprotect,nolvp,nodebug,usbdiv,pll5,cpudiv1,novregen,nopbaden
#DEVICE ADC=8                                              // resolucion a 8 bits
#use delay(clock=48000000)                            // clock de trabajo del pic a  48Mhz
#define LCD_DATA_PORT getenv("SFR:PORTB")   // declaro usar el portb para el control del lcd
#include <lcd.c>                            // libreria del lcd
#include <DSS1302.c>                    //Definimos pines DS1307
///VARIABLES GLOBALES
byte day,mth,year,dow,hour,min,sec;   //variabes para ds1302
byte menu=0,flag=0,var=2;    //variables para menu configurar
///DEFINICION DE FUNCIONES
void configurar(void);
void horas(void);
void minutos(void);
void dia(void);
void mes(void);
void anio(void);
void beep(void);
///LLAMADA FUNCION INTERRUPCION
#INT_TIMER0
void interrupcion()
if(flag>var){    //¿ya es 130ms aprox?
var--;    //SI -> decremento var...
if(var==0)
var=2;    //...ajuste fino de 130ms aprox
flag=0;    //reset flag para contar 130ms aprox
//lcd
set_timer0(0);    //reset TMR0
flag++;    //incremento variable flag
///PROGRAMA
void main(void){
enable_interrupts(INT_TIMER0);    //interrupcion TIMER0 activada
setup_counters(RTCC_INTERNAL,RTCC_DIV_256);   //configuracion interrupcion TMR0
set_timer0(0);    //carga TMR0
lcd_init(); //inicializa lcd
rtc_init(); //inicializa rtc
rtc_get_date(day,mth,year,dow);    //coge dia,mes,año
rtc_get_time(hour,min,sec );    //coge hora,minuto,segundo
lcd_putc("\f fonzo reloaded\n");
   while (TRUE) {
   while (input_state(PIN_D6)==0&& input_state(PIN_D4)==0&& input_state(PIN_D3)==0){
      printf(lcd_putc,"\f seleccione una \n opcion ");
   if (input_state(PIN_D3)==1&&input_state(PIN_D6)==0&& input_state(PIN_D4)==0)
   {printf(lcd_putc,"\f AUDIO  \n");
     output_high( PIN_D0 );
     Lcd_putc( "\f");   //clear
  if (input_state(PIN_D3)==0&&input_state(PIN_D6)==0&& input_state(PIN_D4)==1){
     printf(lcd_putc,"\f recordatorio  \n");
     output_high( PIN_D1 );
     //grabador de voz
if (input_state(PIN_D3)==0&&input_state(PIN_D6)==1&& input_state(PIN_D4)==0){
printf(lcd_putc,"\fFecha: %2X/%2X/%2X\nHora: %2X:%2X:%2X",day,mth,year,hour,min,sec);
configurar();    //ve a menu configurar
enable_interrupts(GLOBAL);    //activadas interrupciones
for( ; ; ){    //bucle...
if(input(PIN_C5)==0){    //Si se pulsa Conf....
while(!input(PIN_C5)){}    //elimina rebotes
beep();
configurar();
}    //ve a menu configurar
} //...infinito
///FUNCION CONFIGURAR
 void configurar(void){
disable_interrupts(GLOBAL);    //desactivadas interrupciones
do{
switch(menu){
case 0:   lcd_putc("\fConfigurar\nhoras?" );    //horas
if(!input(PIN_D4)){
while(!input(PIN_D4)){}
beep();
horas();
menu=1;
//apunta siguiente opcion
case 1: lcd_putc("\fConfigurar\nminutos?" );    //minutos
if(!input(PIN_C5)){
beep();
minutos();
menu=2;
case 2: lcd_putc("\fConfigurar\ndia?" );    //dias
if(!input(PIN_C5)){
beep();
dia();
menu=3;
case 3: lcd_putc("\fConfigurar\nmes?" );    //mes
if(!input(PIN_C5)){
beep();
mes();
menu=4;
case 4: lcd_putc("\fConfigurar\nanio?" );    //años
if(!input(PIN_C5)){
beep();
anio();
menu=5;
case 5: lcd_putc("\fSalir\nconfigurar?" );    //salir configuracion
if(!input(PIN_C5)){
menu=6;
beep();
if(!input(PIN_C4)){    //controla el boton up...
while(!input(PIN_C4)){}
menu++;
if(menu>5)
menu=0;
}    //...para mostrar menu por lcd
delay_ms(130);    //retardo para ver lcd
}while(menu<6);
menu=0;
//actualiza indices menu
rtc_set_datetime(day,mth,year,dow,hour,min);   //nueva hora,minuto,...
//interrupciones
set_timer0(0);
//carga TMR0
///FUNCION CONFIGURA HORAS
void horas(void){
printf(lcd_putc,"\fConf.Horas:\nHora: %2X:%2X:%2X",hour,min,sec);   //muestra por lcd
do{
if(!input(PIN_C4)){    //¿se ha pulsado up?
while(!input(PIN_C4)){}    //elimina rebotes
hour++;    //SI ->
//incremento hour
switch(hour){    //limites...
case 0x0A:   hour=0x10;break;
case 0x1A:   hour=0x20;break;
case 0x24:   hour=0x00;
//...hour
printf(lcd_putc,"\nHora: %2X:%2X:%2X",hour,min,sec);   //muestra por lcd hour
}while(input(PIN_C5));
///FUNCION CONFIGURA MINUTOS
void minutos(void){
printf(lcd_putc,"\fConf.Minutos:\nHora: %2X:%2X:%2X",hour,min,sec);   //muestra por lcd
do{
min++;    //SI -> incremento min
switch(min){    //limites...
case 0x0A:   min=0x10;break;
case 0x1A:   min=0x20;break;
case 0x2A:   min=0x30;break;
case 0x3A:   min=0x40;break;
case 0x4A:   min=0x50;break;
case 0x5A:   min=0x00;
}    //...min
printf(lcd_putc,"\nHora: %2X:%2X:%2X",hour,min,sec);   //muestra por lcd min
///FUNCION CONFIGURA DIAS
void dia(void){
printf(lcd_putc,"\fConf.Dias:\nFecha: %2X/%2X/%2X",day,mth,year);   //muestra por lcd
do{
day++;    //SI -> incremento day
switch(day){    //limites...
case 0x0A:   day=0x10;break;
case 0x1A:   day=0x20;break;
case 0x2A:   day=0x30;break;
case 0x32:   day=0x01;
}    //...day
//muestra por lcd day
///FUNCION CONFIGURA MES
void mes(void){
printf(lcd_putc,"\fConf.Mes:\nFecha: %2X/%2X/%2X",day,mth,year);   //muestra por lcd
do{
mth++;    //SI -> incremento mth
switch(mth){    //limites...
case 0x0A:   mth=0x10;break;
case 0x13:   mth=0x01;
}    //...mth
///FUNCION CONFIGURA AÑOS
void anio(void){
printf(lcd_putc,"\fConf.Anio:\nFecha: %2X/%2X/%2X",day,mth,year);   //muestra por lcd
do{
year++;    //SI -> 1incremento mth
switch(year){    //limites...
case 0x0A:   year=0x10;break;
case 0x1A:   year=0x20;break;
case 0x2A:   year=0x30;break;
case 0x3A:   year=0x40;break;
case 0x4A:   year=0x50;break;
case 0x5A:   year=0x60;break;
case 0x6A:   year=0x70;break;
case 0x7A:   year=0x80;break;
case 0x8A:   year=0x90;break;
case 0x9A:   year=0x00;
}    //...year
///FUNCION BEEP
void beep(void){
output_high(PIN_A3);   //activa zumbador
delay_ms(50);
output_low(PIN_A3);    //desactiva zumbador
[/code]
PostPosted: Fri Apr 19, 2013 2:06 pm     Reply with quote
It doesn't compile because your braces are all mis-matched.
You have too many braces in the wrong place.
Clean up the formatting of your routines. Carefully place all braces
and look at the matching brace.
If you're using MPLAB, you can select (highlight) a brace, then right-click
and select the Advanced menu, and select Match. Then it will show the
matching brace in your program. This can help you to find mistakes.
Basically, don't ever do braces like this:
This is a mess, and will cause endless problems.
Mike Walne
PostPosted: Fri Apr 19, 2013 2:26 pm     Reply with quote
I do it this way:-
Each closing } brace appears immediately below its opening { brace with white space between.
That way, it's usually obvious where the problem is.
  code here level 1;
     code here level 2;
     more code level 2;
  more code level 1;
  even more level 1;
Structure and flow are now much clearer!
Makes no difference now in English, Spanish, French, .............
I'm not even going to attempt to decipher your original effort.
Mike
