PIC oscillator tutorial
Jean FOUGERON
PostPosted: Fri Apr 19, 2013 6:16 am     Reply with quote
Hi friends
I definitely am lost with all these different oscillator modes
Do you know where to find a clear and precise tutorial on it
For example, when I use a 20 MHz resonnator and #fuse HS what frequency my clock is ?
and HSPLL : 2 times ?
Which value have I to specify in #use delay : 20000000 oor 40000000
And in these cases, how the PIC knows to produce a USB 48MHz and not a 24MHz ?
You can derstand that I am lost, and because I am afraid not to be alone in this situation, please somebody give us a CLEAR and understable TUTORIAL
Good WE
asmboy
PostPosted: Fri Apr 19, 2013 7:59 am     Reply with quote
#use delay should always be the ULTIMATE frequency , including any PLL multiplication.
so 10mhz xtal with PLLx4 would be 40mhz
and so on
Jean FOUGERON
PostPosted: Fri Apr 19, 2013 8:19 am     Reply with quote
Do #FUSES HS,PLL5 have sense ? or //#FUSES HSPLL,PLL5 is correct ?
And in this case the freq. is 20MHz or more (with a 20M resonator).
asmboy
PostPosted: Fri Apr 19, 2013 8:28 am     Reply with quote
#fuses mirror the datasheet features of the actual PIC
different oscillator PLL settings depend on individual pic models
let the DATASheet for your model pic be your guide
( you never specified what PIC you are working with )
PLL X4 is the MOST common
if in doubt - set a timing loop with timer0, at a precise divisor and then
toggle a pin at a given rate , then measure the pin toggle frequency.
simple experiment you can do to know what result you are really getting
Jean FOUGERON
PostPosted: Fri Apr 19, 2013 8:38 am     Reply with quote
I use a PIC18F2550 with a resonator 20MHz
With #FUSES HS and #use delay(clock=20000000) -> Time3 div_by_1 == 5,48ms
With #FUSES HS,PLL2 and #use delay(clock=20000000) -> Time3 div_by_1 == 5,48ms
With #FUSES HSPLL,PLL2 and #use delay(clock=20000000) -> it doesn't work
With #FUSES HSPLL,PLL2 and #use delay(clock=40000000) -> it doesn't work
And what configuration have I to use if I want a reliable USB ?
Thanks for all
asmboy
PostPosted: Fri Apr 19, 2013 10:43 am     Reply with quote
reliable USB ?
USB1.1 ?? or USB2.x ???
and still you don't say WHAT PIC ???????
Douglas Kennedy
PostPosted: Fri Apr 19, 2013 11:02 am     Reply with quote
Well, the issue with usb is that usb has its own dictate of a 24Mhz clock.
(usb 2.0 D+ D- wires) The pic internal usb clock or the pic code clock can be different. Now since the pic clock and the usb clock are derived from the same external frequency the external frequency is constrained to some multiple of a common divisor.
EX 18F2455 16mhz xtal common divisors are 2 ,4 , 8 ,16
We must choose 4 since only with PLL4 in the fuses can we get 16mhz down to 4 mhz ready for multiplication to the pic internal usb clock ( a fixed multiple of 24mhz) the 18F2455 data sheet says the internal usb has a fixed 24 x PLL and needs 96 mhz for the internal usb part. So 16 mhz is prescaled to 4hz by PLL4 and in the pic usb circuit rescaled once more to 96Mhz via an internal clock multiplied of 24x
Now suppose we want our pic code to run at 32 mhz but we now know the internal is at 96Mhz
#use delay(clock=32000000) then we need CPUDIV2 which is a bit confusing since it is really divide by three to get 32Mhz.
A recap the external 16Mhz clock was manipulated to 96Mhz for the pic internal usb needs and then the 96mhz was then reduced to 32Mhz for our pic code needs.
Perhaps this is not a good explanation and maybe others have a better way of explaining it. The constraint is the usb part of the pic has a chip data sheet dictated osc freq. The user frequency is then constrained by this and the avialable divisors specified in the fuses statement.
An aside
Je crois qu'une explanation en francais va etre aussi complique. Par hazard Jean votre anglais est formidable.
PostPosted: Fri Apr 19, 2013 11:20 am     Reply with quote
Thanks for all
With this chip, the PLL, _must_ be fed with 4MHz.
So PLL5, is the only legal PLL divisor with a 20MHz clock. With 20MHz, this is _required_ to give the 96MHz USB clock.
Then understand that the PLL always runs. HS means 'feed the CPU clock off the master oscillator without the PLL', while HSPLL means 'feed the CPU clock off the USB PLL output'. The PLL stays running in both cases.
Since the PLL output is 96MHz, you cannot get 20MHz using HSPLL. You need to select HS instead. Then with CPUDIV1, your CPU will be running at 20MHz.
Now if you look at the data sheet, you have four dividers (called by CCS CPUDIV1, CPUDIV2, CPUDI3, and CPUDIV4). If using 'HS', these specify the division to be used from the master clock to feed the CPU.
So if you specify CPUDIV2, your CPU runs at 10MHz, etc..
However when you specify HSPLL, the division starts from the 96MHz clock, and the division ratios change.
CPUDIV1 gives /2
CPUDIV2 gives /3
CPUDIV3 gives /4
CPUDIV4 gives /6
So possible clocks are 48MHz, 32, 24, and 16MHz. These are always the _only_ clocks possible when HSPLL is selected (since the PLL always gives 96MHz).
Jean FOUGERON
PostPosted: Mon Apr 22, 2013 2:26 am     Reply with quote
asmboy wrote:
reliable USB ?
USB1.1 ?? or USB2.x ??? USB2
Jean FOUGERON
PostPosted: Mon Apr 22, 2013 2:30 am     Reply with quote
Douglas Kennedy wrote:
An aside
Thanks so much Douglas, it is kind of you.
Yes these chock manipulations are a bit confusing, I would like to fiind a clear table sheet with all the #FUSES well explained. Maybe I am not the only one in this case ?
PostPosted: Mon Apr 22, 2013 3:57 am     Reply with quote
The translation between CCS fuses and 'what they actually are', is in the document 'fuses.txt' that comes with the compiler. This is an 'often missed resource'.
Then the reference from this, is the data sheet.
Some are really annoying like the CPUDIV ones. Problem here is that (for instance) the pattern 01, means /2, when used with the crystal as an input yet /3 from the PLL. CCS in their 'wisdom' elected to call this fuse CPUDIV2, and give the description '/2 postscaler', but this is simply wrong from the PLL....
Personally I wish they had been a little less 'spoon-feeding' in their thinking, and on fuses like this, used the binary patterns, so you'd have CPUDIV00 CPUVIV01 CPUDIV10 & CPUDIV11, with the numbers corresponding to the binary values put into the CPUDIV bits, then a simple look in the data sheet would give the actual dividers without any confusion....
