Float value into bytes
pavelustinov
PostPosted: Tue Apr 09, 2013 4:25 am     Reply with quote
Hello everybody!
I try to divide a float value like this
float temperature;
temperature = 23.5;
dec = int(temperature / 10);// must be 2
I want to have int "2" in dec variable.
When i compile, i get an error
A numeric expression must appear here
How can i split float value into separate bytes?
PostPosted: Tue Apr 09, 2013 4:55 am     Reply with quote
Your syntax is wrong. Missing brackets:
float temperature;
temperature = 23.5;
dec = (int)(temperature / 10);// must be 2
You are telling it to call a function called 'int', not convert the result to an int....
pavelustinov
PostPosted: Tue Apr 09, 2013 6:09 am     Reply with quote
Thank you very much.
I have one more question.
I need convert to string, ASCII string
P.S. I found answer, thanks to all
